KCStudly wrote:It is looking really nice.![]()
Do the roof top panels and corners over lap the vertical skins like shingles? In that last pic it looks like they slip behind the vertical skins. It would be better if the panels shed water rather than trap it.
Thanks KC for the hint - yes, you are right, but only here in the front !
The front panel is the "crest" of the whole skin and will overlap the roof and corners.
While driving the big air pressure will drive the rain drops here from the front panel up over the roof to the stern.
From the front to the stern every panel will overlap the panels behind.
The seams I will seal with sikaflex polyurethane glue, so that, when the trailer stands, no water should soak inside that single seam in the front.
