Stainless Steel Micro-Airstream behind motorcycle
Re: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Mon Mar 10, 2014 5:34 am
KCStudly wrote:It is looking really nice. :thumbsup:
Do the roof top panels and corners over lap the vertical skins like shingles? In that last pic it looks like they slip behind the vertical skins. It would be better if the panels shed water rather than trap it.
Thanks KC for the hint - yes, you are right, but only here in the front !
The front panel is the "crest" of the whole skin and will overlap the roof and corners.
While driving the big air pressure will drive the rain drops here from the front panel up over the roof to the stern.
From the front to the stern every panel will overlap the panels behind.
The seams I will seal with sikaflex polyurethane glue, so that, when the trailer stands, no water should soak inside that single seam in the front.
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
Postby KCStudly » Mon Mar 10, 2014 6:20 am
Sikaflex is good stuff. :thumbsup:
Postby labuski » Tue Mar 11, 2014 9:05 pm
what are you going to do for insulation?
labuski
87: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Fri Mar 14, 2014 5:16 pm
@labuski - for the moment I plan no insulation.
Today I cut my last sheet for the skin, drilled the holes along the border and puzzled all together on the frame.
Then drilled all holes thru the overlapping sheets and into the frame.
Tomorrow is the big day, I will disassemble the whole body, deburr all the new holes, degrease frame and sheets with acetone and then ...
... shoot all together again with my rivet gun ! And if I'm successful, I can take new pictures without clecos on sunday !
Good night - Tom
1977 Eriba Troll
ST1100
Images: 199
Postby KCStudly » Fri Mar 14, 2014 7:34 pm
Very cool. :thumbsup:
88: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Mar 15, 2014 4:09 pm
Okay - after disassembling the whole box I had to clean all with acetone and deburr the remaining holes.
Then I sealed the frame under the sheets with sikaflex 221 polyurethane glue and clecoed the first sheets on it, beginning from the stern.
Under every new sheet border I layed a line of sikaflex before fixing it with clecos and riveting me slowly from the stern to the front.
1977 Eriba Troll
ST1100
Images: 199
89: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Mar 15, 2014 4:13 pm
And eight hours later I finished with the front sheet.
TADAH !
View of the roof !
1977 Eriba Troll
ST1100
Images: 199
Postby ST1100 » Sat Mar 15, 2014 4:43 pm
And - the best view I think :
and the other side:
A long day with a very satisfying result !
1977 Eriba Troll
ST1100
Images: 199
Postby Greg M » Sat Mar 15, 2014 5:58 pm
If your arms weren't so tired from wielding the rivet gun all day, I'd tell you to give yourself a pat on the back. It's looking fantastic!
Greg M
*Geek Extraordinaire
Images: 85
Postby Martiangod » Sat Mar 15, 2014 8:38 pm
Its come a long way from your living room floor.
Must feel " Oh so good " to be at this stage. Almost makes ya want to lay down in it and have a nap.
:beer: You deserve it
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby danlott » Sat Mar 15, 2014 10:19 pm
ST1100 wrote:And - the best view I think :
and the other side:
It looks like your corners bottom edges are not overlapping the same way?
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby ST1100 » Sun Mar 16, 2014 6:38 am
danlott wrote:It looks like your corners bottom edges are not overlapping the same way?
Dan
Thats correct Dan - if I drive in the rain, the water will be blown up the front over the roof, so the front sheet is the "top shingle" of the whole construction.
If I stand still, the gravity will not have the same power to leak inside the trailer as the dynamic pressure of 60 mph speed.
1977 Eriba Troll
ST1100
Images: 199
Postby capnTelescope » Sun Mar 16, 2014 8:30 pm
OUTSTANDING! :applause: :thumbsup:
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby KCStudly » Mon Mar 17, 2014 2:56 pm
Stunning results! Great craftsmanship! :thumbsup: :applause: :thumbsup: :applause:
Units and Sizes
Postby ST1100 » Fri Mar 21, 2014 6:20 am
For we in Europe use the metric system, I will translate some sizes to you for better understanding.
The trailer is with the tongue 2.56 Meter (8 ft 5 in) long, 100 centimeters (3 ft 3 in)) wide and the platform 200 cm (6 ft 6 in) long.
The rectangular aluminum tube for my frames is 20 x 20 x 2 mm (25/32 x 25/32 inch with 5/64 inch walls)
The stainless(1.4301 - V2A) skin is 0.6 millimeters (1/32 in) thick.
I use watertight 4 millimeter (5/32 in) aluminum rivets with closed ends and stainless pin.
The wheels are standard 8" trailer wheels and the weight of the trailer without sleeping box is 78 kg (172 lb).
Tongue weight is 10 percent of the trailer weight.
The aimed empty weight with sleeping box will be 135 kg (297 lb) and I am allowed to tow 190 kg (418 lb) with my 100 hp Honda ST 1100.
The inside height of the 6.6 x 3.3 ft wide sleeping box is 95 cm (3 ft 1 in) so I can sit inside without touching the roof.
1977 Eriba Troll
ST1100
Images: 199
