Hardryder56 wrote:Jeff,
Based on what I know about fiberglass and seeing the way you designed the system I figured it was going to be strong. Don't worry about anything but your Mom, Moms are important. Prayers and Good vibes going out for her.
KCStudly wrote:How is the seam made between the curved panels and the ply? If both the plywood and the curved panels rest on the flanges of the corner pieces, doesn't that mean the the cut curved panels butt to the ply? If correct, I assume that there is a batten backing each of these joints.
KCStudly wrote:Thank you for the very thorough answer, which was essentially, yes, you glue a batten over the butt joint.
Watercamper wrote:I had to google RTT - Roof Top Tent (it was easy to figure out that it wasn't an acronym for the Reynolds Transport TheoremBut I couldn't find good enough info on the mechanism. I'm interested in seeing/understanding it. Do you have a site with more info? Thanks!
