MtnDon wrote:what is the span between support framework and what size is the framing?
kayakdlk wrote:For my 5'x10' floor I used 1"x3" pine board laid flat for my frame with spans of about 24" to align with my trailer frame cross members. I then use 3/4 foam between the voids and skinned with 1/8" Baltic Birch top and bottom, using PL premium glue troweled evenly over wood frame and foam. It was very solid and I could kneel or stand on it (approx 200 lbs). The foam glued between the plywood stiffens up the whole panel. Quarter inch plywood would be more than enough. Inside you will be on mattress so the weight is spread out.
Dan
Users browsing this forum: jgmahoney and 9 guests
