KCStudly wrote:mdk wrote:...I'm not intending to build a teardrop, nor use it the average way.
This last bit is the most crucial part to answering your question! We need more information. If not a TD, just what do you plan on building and how do you plan to use it?
A mostly frameless 'box' made of "SIP" construction - that is, foam bonded to ply - top, bottom, and sides. external dimensions of 78W X 80H X 172L, with a blunted V added to the front of 36in.
It won't be a just a hollow box with stuff sitting in it and the ends will be structural as well. All the cabinetry will be designed and installed to add structural strength and add to the vertical strength of the walls, to keep the top straight up, if you understand what I mean.
Most all of the small campers built here rely on the composite strength of the complete structure, primarily the depth (height) of the side walls and cross bracing from the bulkhead and front walls for the majority of their integrity. The box provides the strength. Build a strong box and you don't even need a proper frame, just solid attachments for the tongue and axles (search ultralight).
Yes, I understand that. And the fact that I'm not building a massively structural box, means that the frame has to have some strength of its own.
For off road use or utility trailers things change. For my pseudo off road build the cabin sits on top of the full perimeter box tube frame. The frame is more there to protect the lower edges of the cabin from damage due to contact from rough terrain, rather than to strengthen the box. The box is already rigid as heck and it isn't on the trailer yet, and doesn't even have the roof on yet!! Don't believe it? See Aggie79's Silver Beatle build. He has a pic of his cabin as it is being built sitting on three jack stands located at the very front and rear. He was able to sit in the doorway with no perceptible sag! Think of the side walls as big tall I-beams that hold the trailer frame up, and the trailer frame as a secure place to attach the axles and tongue, rather than the frame holding the cabin.
Well, I have the same idea, except that size and shape, along with the need to reduce weight (and keep center of gravity as absolutely as low as possible) means it won't be quite as strong as that - or at least I don't expect it to be.
The curvature in the roof adds a lot of structural stability, too, adding stiffness in multiple planes, so that is another plus for more traditional builds.
yeah, in this case, no curved roof - though I have thought about making the last 4-5 feet feet slope downwards some, as it's nothing but the bed and dinette. You'll never stand at all in the last 3 feet toward the back.
Utility trailers with no box, and cargo trailers with flat roofs, no rear bulkheads and large opening rear doors, not to mention higher load expectations, can't be built as lightly.
Think of this as shaped like a V-nose cargo trailer, but no big end door and with some partial bulkheads near the center.
My start to this is to use 1.5w X 2h x 16 ga perimeter tubing, plus 1x1.5 x 16ga laterals, except most of the front which will have 2x1.5 x 1/8 or heavier. two full length 3x3 x 1/8 beams 14 inches in from the edges, boxed in back and front, ( a 4x4 sheet metal box for storing sewer hose as a "bumper").
Then, 2W x 4H X 72 long X 3/16 members under the full length beams to which are attached the suspension. They, too, to be gusseted/boxed to prevent lateral deflection.
I calculate this, with tongue of 2x3 heavy tubes in a shallow V (tongue extends out 5 feet or a little more from the "box" of the trailer to add sharp turning ability) but no suspension attached, will weigh under 400 lbs. The whole thing was conceived to add strength to a 3/8 ply (top) X 1.5 foam (middle) x 1/4 ply (bottom) floor, by turning everything into a mostly cantilevered beam, none of which have more than 250 lbs at any point under any condition. The main beam is light, while the suspension load is spread across 6 feet of it by two extremely strong beams with adequate thickness to get really good welds for suspension mounts.
The gray and black water tanks will be boxed into the laterals and touch the floor itself, for maximum ground clearance.
By using 205/65-10 wheels/tires (tandem axle) the entire tire will go UNDER the floor with no wheel well, with a "bottom of the floor / top of the metal frame" height of 25.5 inches and with the tanks tucked up as far as possible, I the lowest point should be 9in and be the axle itself, the next lowest be the tanks at about 14 - 15 inches, with the biggest / lowest being mostly forward of the front axle. I want to be able to navigate logging roads, back roads in AZ and UT and NV without dragging or busting the plumbing. Even my truck won't have quite as much axle clearance at its lowest point, as the trailer will.
Tell us more about your plan and I'm sure we can help.
Hope this helps.
5 out of 4 people are bad at math.
