fiberglass m100 kit painting
Postby 123jay » Wed Apr 16, 2014 11:21 pm
I am putting together a M 100 fiberglass trailer kit it came in this bright white gel-coat.My plan is to paint with feather fill primer .To get to the color I want will use rust-oleum hunter green and flat white and baking soda to get the look I want .
What I need to know is what grit of sandpaper do I use to rough up the gel- coat this trailer has resets in it.
What is the best way to deal with them? Thank you
401/2"X 48" open tailgate bolt together army kit around $450.00
If the world did not suck ,you fall off!
123jay
Re: fiberglass m100 kit painting
Postby Dale M. » Thu Apr 17, 2014 9:09 am
Light scuff sanding with 600 wet/dry to break the sheen (gloss) and give some tooth for the new paint would probably do it...
Generally I treat fiberglass finishes just like any automotive finishes, procedural wise... Block sanding would probably be best process to not leave finger groves in scuff sanding on main surfaces.... Simple hand sand or foam rubber or sponge in recess areas....
Again all you are trying to do is break the sheen (gloss) of the gel coat and give some tooth for the new paint ...
Dale
Dale M.
Images: 18
Postby 123jay » Fri Apr 18, 2014 5:20 pm
Thanks Dale for the fast reply . I am going to try to get painted this weekend
123jay
Postby George Taylor » Sat Apr 19, 2014 8:15 pm
I would recommend spending the money and have an automotive paint place mix up some paint the color you want.
George Taylor
Postby 123jay » Sun Apr 20, 2014 3:33 pm
George Taylor thanks for your input..To get the car paint I wanted to have the look was over $ 348 with all the things I had to buy HARDENER,REDUCER .
Where I go it has a lot of things to mess the paint up so will have to repaint a few times a year
123jay
Postby jscherb » Sun Apr 20, 2014 4:25 pm
This one is a fiberglass tub, fiberglass hard cover, Harbor Freight frame (was red) and metal fenders, all painted with Hot Rod Flatz Olive Drab from TCP Global. Gallon kit includes hardener and reducer. I used probably 3/4 gallon to paint everything. I did shoot everything first with 2 coats of epoxy primer. Cost of paint materials was about $200 including the epoxy primer.
jscherb
Postby SLUG36 » Sun Apr 20, 2014 5:54 pm
use a red colored scotch brite pad. you usually can find them at auto parts stores. we used them when I worked at a auto body/paint shop.
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Postby 123jay » Sun Apr 20, 2014 10:48 pm
Thanks jscherb & SLUG36 for your in put.
I live across the street from the HOA want be cop. He has call the air board on people using can spray paint you have to use the water based paint . So here it high price
As you can see it covers part of the frame that will be black . The reset will be the same black and the field will be green
The tailgate will be ALU . plate.
123jay
Users browsing this forum: featherliteCT1 and 3 guests
