GuitarPhotog wrote:I just use the tongue jack in the front and two screw-jack stabilizing jacks in the back. I don't worry so much about the wiggles, but need to have the galley level for cooking.
<Chas>
<Chas>
However, if I had wanted to level the trailer (if situated on a flat pad at a campsite), I would've attached the tongue jack, lowered the nose about an inch, then release the "bar-clamp stabilizers" (which support up to 600lbs each) on the rear corners. Their design is such that they slide down to rest the feet on the ground, and lock in place. Then I return to the tongue jack, and raise the nose until the bubble-level indicates that it is level (usually, about the inch I had lowered it). At that point, the trailer is supported at 5 points: 2(rear-stabilizers), 2(sides-tires), 1(front-jack). I have not had to use this system on un-level ground, yet, but I have tested it. I use the same procedure (the "inch" may be in multiples) for fore and aft levelling, but for side to side, or four corner levelling, I carry an old bumper jack from my Chevelle (shown in my avatar), which I use to raise the sides or rear up to 18" over normal height. Once level, I can drop the stabilizers down (up to 30" of variable adjustment) to the ground. I carry 4 barbell weights along, which I can use as additional base pads for the jack or stabilizers (if not, then to weigh down the canopy, if I choose). If more levelling or bracing material is needed (doubtful, since I'm not off-roading), I have additional treated 2"x*8 lumber (used as partitions in the bed of the truck), which can easily be temporarily pressed into service. I figured that I needed to cover all the bases, just in case, so that's why the stabilizers are so long.
aggie79 wrote:We have the same setup as you.
We back into the space. After unhooking the TD. I lower the front jack so the TD is slightly out of level (with the galley end high). Then I level the galley end side to side. Lastly, I raise the front jack so the teardrop is level front to back. With this three point stance plus the trailer tires, we don't get the wiggles.
