Ron Dickey wrote:
What do you mean by spring back?
Ron
When you bend a flat piece of plywood in a curve, it really doesn't want to be bent. I wants to spring back to its original shape... Thus spring back. Over time, the plywood will get trained to the curve shape and stay that way on its own, but it takes years. In the mean time, the relatively thin ribs in the hatch have to withstand that spring back in addition to any force you put on it by lifting the galley lid.
Some people make a jig to train the plywood for the galley hatch over several weeks or months while they are building the rest of the tear. This enables them to keep the hatch lighter as the ribs don't have to be as large with the plywood pre trained. My hatch skeleton was my jig, and it stayed in and heavy. Some people build with finesse... I guess I just build with brute force.
By the way, in my very dry desert climate, it helped to wet the plywood when bending. I kept these towels damp while I was bending the plywood around my hatch. Aka... Mr Incredible and Scooby team up to bend my hatch! Over a day or two, I tightened the straps until the plywood took the shape of the hatch. Then I let the towels dry and left it that way for a week. After that week, I until-clamped, removed the towels, applied liberal amounts of glue to the partially trained plywood and re clamped for another week. Ofter that... Rock solid. I can lift it pretty easy. My 15 year old boy can lift it. My wife doesn't try. You can put in gas struts to help or totally compensate for the weight. Mine doesn't have gas struts, just sliding prop bars that latch open.
See the black dots on the lower part of the hatch? Those are screws from when I glued and screwed on the lower flat piece. The upper portion has no black dots. That is because it was clamped until the glue dried, no screws. Most f my teardrop was built with glue and screw. The screws provided the hold and clamp while the glue dried. I did not use external clamps hardly at all. This results in a lot of screws left in the teardop. While not a horrible thing, it is not exactly the finesse or master craftsman way to do things.
