Question re: Installing window in CT door
Postby willfish4fud » Thu Jul 24, 2014 11:56 am
Im curious as to the typical construction inside of a CT door. I need a window in my door and am wondering what you typically find when you open it up and therefore what it will take to do it. Thanks
willfish4fud
Re: Question re: Installing window in CT door
Postby bc toys » Thu Jul 24, 2014 9:16 pm
I cant answer this but just starting my build let us know what you find when you open it up I'm putting my windows in the sides above wheel wells
bc toys
Images: 42
Postby willfish4fud » Thu Jul 24, 2014 10:10 pm
bc toys wrote:I cant answer this but just starting my build let us know what you find when you open it up I'm putting my windows in the sides above wheel wells
I def will if I open it up...but Im hoping someone who already has will speak up...hate to get a bad surprise
willfish4fud
Postby AZKayaker » Thu Jul 24, 2014 10:31 pm
My door is foam with aluminum skin on either side. A sabre saw with a medium blade cut it like butter. Here's a pic of the hole before window installation.
See my 5x9 SquareDrop CT conversion build, trip pics and more
gallery/album.php?album_id=3552
AZKayaker
Images: 38
Postby willfish4fud » Thu Jul 24, 2014 10:44 pm
AZKayaker wrote:My door is foam with aluminum skin on either side. A sabre saw with a medium blade cut it like butter. Here's a pic of the hole before window installation.
Thanks for that. Exactly what I was wondering about. Mine is skinned with wood on inside but am thinking it could be same inside. Unless its hollow/partially hollow???
willfish4fud
Postby mikesova » Fri Jul 25, 2014 9:27 am
Also interested in the results. Mine is also wood on the inside, outside skinned with aluminum and the hinges are the big heavy duty strap hinges.
mikesova
Postby wtcreaux » Fri Jul 25, 2014 12:20 pm
Mine was wood but partially hollow. Use a sabre saw with a fine blade. I didn't have my sabre saw so used a sawzall which made too rough a cut. Also if you door is partially hollow, insert wood or foam to provide a "solid" area of cutting, prevents the metal side from bending in........don't ask me how I know :shock:
wtcreaux
Images: 211
Postby hankaye » Fri Jul 25, 2014 9:57 pm
willfish4fud, Howdy;
I ordered an RV door for mine and the door that came with it is foam core.
hank
hankaye
Postby willfish4fud » Wed Jul 30, 2014 6:18 pm
made the cut out in my door today and it is styrofoam filled like azkayaker photos. Cut smooth will jigsaw n metal blade
willfish4fud
Postby willfish4fud » Wed Jul 30, 2014 9:00 pm
Foam cored door
pace 6x10 window in door.png (232.3 KiB) Viewed 3409 times
willfish4fud
Postby AZKayaker » Wed Jul 30, 2014 10:45 pm
Sweet!
AZKayaker
Images: 38
Postby willfish4fud » Thu Jul 31, 2014 7:55 am
Just FYI the service guy at the dealer told me that Styrofoam core is pretty much the standard these days and the only thing to watch out for regarding structural members is near the door lock
willfish4fud
Postby Quadriderdad » Wed Aug 27, 2014 7:40 am
Mine are solid plywood. Unfortunately they are made up of two pieces instead of one....not real happy about that.
Quadriderdad
Images: 51
Postby cornfused » Thu Aug 28, 2014 11:09 am
My door had a metal frame and was hollow on the inside. I ended up lining it with foam.
cornfused
Postby sbshaver » Tue Sep 09, 2014 10:05 pm
Quadriderdad wrote:Mine are solid plywood. Unfortunately they are made up of two pieces instead of one....not real happy about that.
Shoddy work. I agree. Two pieces of plywood stapled together.
sbshaver
