1st time build, Suprise for the wife (9-10,wall panel added)
Re: 1st time build, A surprise for the Wife :)
Postby BuildingForFun » Fri Jul 25, 2014 12:29 pm
KC, Thanks, shes a 70 original 4 speed SS, drive line is original except for the motor, has 400 sbc instead of the 350.
Nova 2.jpeg (144.35 KiB) Viewed 1712 times
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 12:53 pm
Some photos of last nites work.
Aluminum floor layer rolled up.
Rolled out.
Cutting to fit the floor.
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 12:55 pm
More.
First layer of 1/4 inch ply wood.
Bare Frame
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 12:59 pm
Watch dog Leyna on duty....Lol
Time to move inside......looks like rain.
photo 1a (1)leyna.jpg (158.33 KiB) Viewed 1710 times
Looks like rain
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 1:02 pm
Trailer is moved all the way inside so garage door can be shut. Good thing I did, few min later the rain came.
Floor Joist on.....and then the foam insulation.
Tonite will try to get top layer of 1/2 inch birch cut and fit.
Joist cut and fit.
Foam cut and fit.
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 1:07 pm
I also wanted to show the RV Camper scissor jack stabilizers. They are not mounted yet, but I put them into position and ran them up and took the weight of the tires....made trailer nice and steady.... also I saw the cool little socket adapter to use with a drill. Man! works sweet and fast!!!
Scissor Jack.
Mounting plate for scissor jack.
In Place.
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 1:15 pm
Jacks and speed socket
Both Jacks in place.
Speed socket
Speed socket and jack.
BuildingForFun
Postby KCStudly » Fri Jul 25, 2014 1:19 pm
Nice. So far, so good. :thumbsup:
Postby BuildingForFun » Fri Jul 25, 2014 2:43 pm
This is the profile of the wall....and then one of it cut out....instead of going with birch plywood for the outer wall, I got the cheaper 1/2 inch plywood, then I was going to do a 1/2inch foam insulation and wall stud, and then a 1/4 inch birch plywood for the interior wall. unfortunately :( I didnt check the plywood for straightness and one of the pieces has a bad bow in it......so after drawing the profile out, cutting, and glueing together....I can use it :cry: :cry: ....Now I am going to go with the more expensive birch now, and at least I can use the first wall as a template. Oh well. You Live and Learn.....bet ill be checking my wood for bows in them....Lol
Wall Profile 2 (1)a.jpg (90.29 KiB) Viewed 1631 times
Wall Profile 2 (2)a.jpg (91.76 KiB) Viewed 1631 times
Wall Profile1 (1)a.jpg (90.34 KiB) Viewed 1631 times
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 2:45 pm
Cut Out.
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 3:48 pm
These are the Bias Ply tire and wheel combo with baby moon caps I will be using.... am still waiting for the wheels to ship....
Coker Tire 1.jpg (59.8 KiB) Viewed 1626 times
Coker tire 2.jpg (63.98 KiB) Viewed 1626 times
Coker tire 3.jpg (65.83 KiB) Viewed 1626 times
BuildingForFun
Postby BuildingForFun » Fri Jul 25, 2014 3:50 pm
Jegs Wheel.
Jegs wheel and moon cap
BuildingForFun
Postby mallymal » Fri Jul 25, 2014 4:30 pm
Wow... Looking forward to seeing this one.... What a great start!
Good luck keeping your wife out of the garage so she doesn't find out about her surprise!
You could always leave a false trail by leaving printouts and sketches lying around of small scale bogus projects... stuff like mug racks, chopping boards etc.... She might still wonder what the hecks going on when you walk up the drive with a sheet of 8x4!
mallymal
Images: 18
Postby CMC » Sat Jul 26, 2014 7:57 am
The way your moving, you will be done pretty quick. Unless teardrop time gets a hold of you ;) . Great start.
Curtis
Finally the build has started. Oversized Off-road Benroy (Military Themed)
CMC
Postby nhstt » Sat Jul 26, 2014 8:00 pm
Caleb,
My husband,son of a electrician,brother of one and unofficial electrician himself to 2.5 houses favorite words are" I am not a carpenter".See what he's been doing with a 11 and 13 year old helping :lol:
Just keep going and spend lots of time lurking on other build journals. ;)
Here's ours,
Karen at the Ladybug-out build journal viewtopic.php?f=50&t=55602
nhstt
