1st time build, Suprise for the wife (9-10,wall panel added)
Re: 1st time build, A surprise for the Wife :)
Postby KCStudly » Sat Jul 26, 2014 8:48 pm
nhstt wrote:My husband... electrician... favorite words are" I am not a carpenter"
Reminds me of a joke I know, :lol: :lol: :lol: ...but I shan't tell it here because it contains swear words.
Postby BuildingForFun » Mon Jul 28, 2014 7:46 am
mallymal wrote:Wow... Looking forward to seeing this one.... What a great start!
Good luck keeping your wife out of the garage so she doesn't find out about her surprise!
You could always leave a false trail by leaving printouts and sketches lying around of small scale bogus projects... stuff like mug racks, chopping boards etc.... She might still wonder what the hecks going on when you walk up the drive with a sheet of 8x4!
Thankfully if I tell her im working on something for her, she will not try to go snooping.....so when the garage door is up, she is inside the house with the curtains drawn tight. lol.
Her curiosity is defenitly up.... with all the lumber being bought. lol, the sheet of 8x4.....Yeah should have her completely confused. lol :)
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 7:49 am
CMC wrote:The way your moving, you will be done pretty quick. Unless teardrop time gets a hold of you ;) . Great start.
Curtis
I hope to keep up the speed.....But im sure it is inevitable, at some point teardrop time will get ahold of me.....I already neglected mowing this weekend...got to do it after work today. But I plan to push as hard as I can and stay moving on it. Time will tell.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 7:51 am
nhstt wrote:Caleb,
My husband,son of a electrician,brother of one and unofficial electrician himself to 2.5 houses favorite words are" I am not a carpenter".See what he's been doing with a 11 and 13 year old helping :lol:
Just keep going and spend lots of time lurking on other build journals. ;)
Here's ours,
Karen at the Ladybug-out build journal viewtopic.php?f=50&t=55602
Thank you. I have viewed your build, you guys are doing great, and what a kool tear drop.
BuildingForFun
Re: 1st time build, A surprise for the Wife :) (Up Date 7-28
Postby BuildingForFun » Mon Jul 28, 2014 8:02 am
So Friday nite I went to Harbor Freight, got wood clamps, saw bucks, a seat, and a roller stand. I also wanted to give a shout out to Rahn, my Favorite Harbor Freight Rep that helped me out getting some things.
Then on to Home Depot to get some Birch ply wood for the walls, and a Belt Sander, Router, and Biscuit Jointer....Wow, This project is starting to feel like Christmas.
Behold the Load.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 8:38 am
So, I didnt get out to the garage on Saturday till about 3:15pm. I started in on trimming and fitting the top layer of the floor. After I got that done I then disasembled the floor to the first layer of the 1/4 inch ply wood and put the lidquid nail glue down for the floor joist.
Top Layer cut and fitted.
Gluing the joist
Glueing the joist
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 8:50 am
Then next I glued the foam insultion, I did have to make a run to Walmart for more Lidquid Nail Glue....it just doesnt go as far as I thought......Then screwed all the joist down to the first layer of plywood.
Glueing the insulation.
2nd Layer complete, now on to the top layer.
BuildingForFun
Postby KCStudly » Mon Jul 28, 2014 9:34 am
Spread the glue with a notched trowel (cheap plastic one will do, or even cut your own... I use fake credit cards that come in the junk mail). The glue will go further and it will give you a better bond.
Postby BuildingForFun » Mon Jul 28, 2014 9:49 am
Next I opened up the new Biscuit Jointer to joint together the top layer of flooring. The instructions that came with it was, "use white wood glue that is water based so that the biscuits will swell and expand, making a strong joint." So while at Walmart I also picked up some Gorilla Wood Glue......Hey, nothings stronger that a Gorilla, So it ought to keep the joint nice and strong...Lol
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 9:51 am
KCStudly wrote:Spread the glue with a notched trowel (cheap plastic one will do, or even cut your own... I use fake credit cards that come in the junk mail). The glue will will go further and it will give you a better bond.
Great Idea......Wish I would have thought of that sooner......I will have more gluing to do.....and I think I have a notched, ridged trowel.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 9:55 am
Gorilla Glue....Should be Super Strong...lol.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 10:03 am
After making the slots with the Jointer. I then glued the 2nd layer of the Joist and Insulation. At all the joints where the Joist met each other, I put a bead of Glue. Then laid the 3rd layer on top, glued the biscuits and joints, And Screwed everything down tight.
2nd layer glued.
Where Joints met, I put an extra bead of glue.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 10:10 am
Over half way done.......
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 10:13 am
And Finally finished up....all jointed together, and screwed down.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 10:16 am
I also laid out the plywood for the wall, and drew out the profile lines. This Weeks Goal is to, (Take the floor off the frame, and glue the aluminum to it. Put back on the frame, bolt to the frame. Then get the walls cut out and temporaily fastened to the floor.)
Last edited by BuildingForFun on Mon Jul 28, 2014 11:25 am, edited 1 time in total.
BuildingForFun
