1st time build, Suprise for the wife (9-10,wall panel added)
Re: 1st time build, A surprise for the Wife :)
Postby BuildingForFun » Mon Jul 28, 2014 10:46 am
Anyone have any sugestions on a glue to use when glueing the aluminum bottom sheet to the floor...... I believe it was on the build of, "Father-Daughter Build 2013-14 by lfrazer98" That I saw to use Vinyl glue, Now I cant find it though, lol .....Below is what I found at Home Depot.... will this work? or any Ideas on What I should Use? Thanks.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 11:22 am
Also I said would list some design drawings.... below is a couple of sketchs. They may not make since to you, but they make perfect since to me Lol ;) Now theres not alot of detail listed, but whats not there is all in my head....and planned out perfect. lol, so I will just keep posting photos as it comes together.... (and the drawings are drawn out on graph paper with one square being 6"x6" to scale......Unfortunantly the scanner didnt pick the squares up....and im not computer savy enough to figur out how to make it.
We are not traditional campers, We wont be needing the gallery that most tear drops have, " No need for Sink or Stove top." So it will still have a Hatch inback, this will be to get a queen size mattess in and out, also I will probably try to make some sort, counter top there. By not having the traditional gallery in back, it will allow me to move the Mattress further back, and put the mini Fridge up front. This will also give room in between the Mattress and front of trailer for a sitting area, and for a collaspable table, the mini fridge and the microwave. (Floor plan photo below) Has anyone did a design like this and have photos? Or any Thoughts on it.
Also there is a side profile sketch of the outside profile, and of the interior layout....(again, not sure if this will make sense to any one but me.)
I will be using a window A/C unit, with cabinets on both sides of it. (And my neighbor is a sales rep for a company that manufactures and sales Wood Paint and also Wood Stains.....And he has his Side Business Shop Set up behind his house that they Refinsh cabinets in.........They are masters at it, so He can help me get a Beautiful stain on the Birch Floor, Walls, and Ceiling. :)
Floor Plan..tif
Interior Floor Plan
Floor Plan..tif (55.46 KiB) Viewed 1807 times
Profile plan..tif
Side Profiler With Interior Layout
Profile plan..tif (66.43 KiB) Viewed 1807 times
Profile.tif
Side Profile With Fenders and Frame
Profile.tif (55.79 KiB) Viewed 1807 times
Last edited by BuildingForFun on Mon Jul 28, 2014 2:22 pm, edited 1 time in total.
BuildingForFun
Postby BuildingForFun » Mon Jul 28, 2014 2:20 pm
Also, does anyone have any advice on what size and kind of wood to use for the Roof Joist? I was considering using a non pressure treated 1x1 piece of wood...but this is what I would consider a rough cut of wood, and the bundle I got, some of the pieces are kinda bowed or warped. Any inmput from anyone? Im wanting somthing strong, straight and precise....Thanks in advance, Caleb.
BuildingForFun
Postby KCStudly » Mon Jul 28, 2014 2:31 pm
"Select" pine, poplar, or cedar; in that order of expense. Look for knot free pieces (because the big box "select" isn't very). I usually find this in the trim section, away from the general framing lumber (probably have to go to a true lumber yard for the cedar).
For hatch hinge spars, you will want to go with something harder that will hold your screws better; maple or oak.
You just can't get knot free framing lumber anymore. The stuff at the Borg is just full of flaws. :thumbdown:
Postby BuildingForFun » Mon Jul 28, 2014 2:50 pm
KCStudly wrote:"Select" pine, poplar, or cedar; in that order of expense. Look for knot free pieces (because the big box "select" isn't very). I usually find this in the trim section, away from the general framing lumber (probably have to go to a true lumber yard for the cedar).
What about the Hatch runners....do these need to be cut out of a sheet of 4x8 plywood with a router? see drawing.....?
Hatch spars..tif
Hatch spars..tif (24.66 KiB) Viewed 1779 times
BuildingForFun
Postby KCStudly » Mon Jul 28, 2014 6:16 pm
Your dwg's aren't working for me; not sure why.
There are many ways to do hatch ribs. I did mine by mitering and butt joining 1x6 Red Grandis using biscuits, and then routing the profiles from a template. (I have not stressed them yet and do have some reservations that the joints will handle the load from the bent ply... still building... so maybe not the best example of a success yet.) I have seen others do a mortise and tenon style of slip joint to join the ends then profile, and still others that reinforce jointed planks with aluminum scabbed on.
I did not want to use plywood because my ribs will remain exposed, and because I did not want to run screws down in between the plys when attaching my inner skin (which goes on the outside of the ribs... foamie hybrid construction).
On the other hand, many, dare I say most people cut their hatch ribs from plywood. If you use whole wood stringers/spacers pocket screwed into the ribs, you can then screw your skins into those instead of the edges of the ribs.
Postby BuildingForFun » Tue Jul 29, 2014 11:10 am
CMC wrote:The way your moving, you will be done pretty quick. Unless teardrop time gets a hold of you ;) . Great start.
Curtis
AAHHHHHH!!!!!!!!!!!! You must of Jinxed me. Teardrop Time is getting ahold of me. I want to be in the garage soo bad, but never made it out to work on it yesterday.....and tonite isnt looking good either. :cry:
BuildingForFun
Postby S. Heisley » Tue Jul 29, 2014 9:04 pm
Titebond III glue works great on bare wood. On epoxied wood, I used PL2000 construction glue.
Your wife is going to figure out what you are doing pretty soon, if she hasn't already. But, the excitement
of seeing the build is a gift in itself. Anyway, she'll probably want to have some say about colors, etc.
Oh, and, yes, your pictures don't seem to be working anymore. :(
Keep building! :thumbsup:
Postby BuildingForFun » Wed Jul 30, 2014 7:26 am
S. Heisley wrote:Titebond III glue works great on bare wood. On epoxied wood, I used PL2000 construction glue.
I will try to pick of that glue up tonite. Also the photos that i have attached of the build arnt working,or loading??
BuildingForFun
Postby BuildingForFun » Wed Jul 30, 2014 8:18 am
So after spending some time looking at some build journals, and around the site here.... I decided ive got to make time to get out in the garage tonite. Going to be tuff though. I have to get two cars emision inspected by the state of NC and we have mid week church tonite. If not tonite, forsure tomorrow nite. Most of our trips will be done on the east coast, but after looking through the Camping and Gatherings section, my appetite was really wetted to do a NC to NM trip, my wifes home state. We usually fly out once a year, but it would be really neat to hit the road, and be able to pull over and sleep when ever.
BuildingForFun
Postby S. Heisley » Wed Jul 30, 2014 5:43 pm
Your pictures show "Attachment" and then a little map-like image that is about 1/4" high, the same image each time.
The weird thing is, I can copy those and paste them into a Word document; and then, the entire picture is displayed on my PC; but, not here, on the forum.
...Don't know what is causing that.
Postby KCStudly » Wed Jul 30, 2014 7:13 pm
Maybe the scanned sketches are a different file format; a .tif ?
Postby treebeau » Wed Jul 30, 2014 9:39 pm
Great so far, neighbor!
Regards,
Tim B.
treebeau
Postby BuildingForFun » Thu Jul 31, 2014 8:31 am
Ok, Let me know if these pictures load, they were saved as a Tif file, I resaved them under another file, so let me know if they are working. its a PNG
Floor plan.
Profile
Profile Plan with layout
Profile plan.aa1.png (42.2 KiB) Viewed 1571 times
BuildingForFun
Postby KCStudly » Thu Jul 31, 2014 8:45 am
Yup, I can see them now. :thumbsup:
