CGRotorhead wrote:Ya can you take some more pics of it? Did you just use the same u bolts and just move the axel from having the spring under to having it over?
cool man thanks for the pics those were what I was looking for. And I'm guessing you just reused the same u bolts?TucsonWJ wrote:CGRotorhead wrote:Ya can you take some more pics of it? Did you just use the same u bolts and just move the axel from having the spring under to having it over?
Her you go CHR, here are a few pictures of the axle flip and the wheel adapters.
Here is the axle flipped under the spring, there is a locating pin on the top of the spring that you need to line up to get it
In the correct position. I'm not sure if they all have one top and bottom of the spring but mine did.
In his picture you can kinda see the slight bend in the axle that should be bent upward, when you flip it you can re weld a new pair to the correct side. I however did not do that. I'm not sure that I am going to, I may leave it till I upgrade to a axle with brakes. Not sure yet.
Here is a picture of he wheel adapters top and bottom. I don't have any pictures of them on, I'm not going to install them till I have the wheels and tires ready to install. You want to use thread locker on them and torque them correctly so I don't want to be taking them on and off after I install them.
Hope the pictures helped.
