Door trim/seal
Door trim/seal
Postby dglenn1960 » Mon May 15, 2006 3:11 pm
Thinking harder about my doors now (floor done and walls are up, pics forthcoming) and have been contemplating having the seal on the inside (like a house door) and using a normal piano hinge. I used 1/2" ply for the walls and can get 1/2 ply alum. edge trim which fits nicely. If I trim the walls with an alum. angle I would have the following (with one or two of the readily available rubber door seals):
<img src="http://www.glennweb.net/home/images/tear_door1.jpg">
Opinions? All edges will be sealed with epoxy (ext. is spar poly).
~dave
dglenn1960
Images: 15
Postby gager2002 » Mon May 15, 2006 3:28 pm
I like the idea. But the corners will need to be square instead of rounded. Or can you do it another way?
gager2002
Postby dglenn1960 » Mon May 15, 2006 3:34 pm
Forgot to add that, yes I'm doing square doors on the moto-tear. You could bend the alum for the door trim but wouldn't be able to for the wall trim as it goes the wrong way (good point). :roll:
~dave [/list]
dglenn1960
Images: 15
