I though about the Raindrop design because of the interior space, but I gave up due to the complexity of its design and construction.
I admire you for taking on the challenge and doing such a great job.
ryuandwings wrote:That looks great!![]()
Gunguy05 wrote:
Serendipitously when we were cleaning up tonight my son had left a sheet of the underlayment material that we had used for the templates lying out in the grass where it had collected dew and was quite bendy. SO...I tried to see how well it would bend to the front curve and ... bingo!
We were going to use an extra layer of the oak ($$ and not too bendy) for the outside sub layer under the skin. This is where the window hole will be cut, and the trimlok gasket will sit. I had been concerned about the stability of this given the thin top later of oak and it's proneness to splinter (thus not giving a good sealing surface for the gasket).. BUT this stuff works great and takes a clean cut on the edge.
Anyways, I gave in and went back outside a few minutes ago and cut a piece to fit and bent it into place. Works like a charm. The outline is where the side window will be, but with radius corners.
Your original sketch showed the window in the flat front portion. What window material can be bent into that curve?
KCStudly wrote:Gettin' er done, and looking nice.
KCStudly wrote:Looking good!![]()
The lines of the TB match the cabin very nicely.
