Mobile Fit Club Build - Tommy2tone_1999
Re: Mobile Fit Club Build - Tommy2tone_1999
Postby Tommy2tone_1999 » Tue Nov 11, 2014 3:42 pm
Thanks so much. I am a rough carpenter at best and I always looks for ways to work with the tools I have at hand. My power center is a Progressive Dynamics PD4045 with a built in charger. I have it located in the center of my galley. My battery is located in the tongue box.
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Postby Tommy2tone_1999 » Tue Nov 11, 2014 3:50 pm
Decided to get the painted aluminum sheets instead of painting the side walls. This will save me a ton of work.
Trimming the edges of the roof flush with the walls
Profile traced onto the back side of the aluminum.
Passenger side wall cut.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:13 pm, edited 2 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Thu Nov 27, 2014 7:31 pm
Just scored two 3" queen size memory foam/support foam bed toppers for my mattress at Wally World for $31 ea. A 5" queen size sheet of regular foam from Foam World is $116 not counting shipping. Woo Hoo!
Tommy2tone_1999
Postby Tommy2tone_1999 » Thu Nov 27, 2014 7:42 pm
Filler applied to the screw holes
Sanding the filler smooth
Applying a couple coats of CPES to the roof and the wall/roof seams
Applied 2 coats of Zinsser Oil-Based Primer to help moisture proof the plywood roof and walls before applying the aluminum to the walls and roof.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:16 pm, edited 1 time in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Fri Nov 28, 2014 4:32 pm
Squirted a bead of 3M 4200 marine adhesive around the outer margin of the wall and all holes and openings and secured the first wall in place while it cures. This secured the aluminum to the wall and will allow it to flex with any changes in temperature. Those who have branded this adhesive "Evil Black Stuff" will be happy to know it also comes in white :lol:
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:18 pm, edited 1 time in total.
Tommy2tone_1999
Postby Martiangod » Fri Nov 28, 2014 8:11 pm
Good to see you treating the wood before applying the aluminum.
Your getting closer to never being done, going to be a good looking little trailer when your done.
The aluminum will be nicer for your advertising decals, then a painted wood surface
Build On !!!
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby Tommy2tone_1999 » Sat Nov 29, 2014 2:54 pm
Thanks, I hope so. I have the driver's side wall up now and clamped, waiting for the glue to cure overnight. The aluminum will also save me a bunch of time over painting. While the glue cures I'll start planning and gathering materials for the hatch.
Tommy2tone_1999
Postby Tommy2tone_1999 » Mon Dec 01, 2014 12:08 pm
Prepared a template for the ribs of my hatch from a scrap piece of luan. The ribs will be made from 3/4" birch plywood. i will rough cut them with a jigsaw then use the router to match the template and then clamp them together and use a belt sander to even them out.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:19 pm, edited 1 time in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Mon Dec 08, 2014 12:26 pm
Galley Hatch ribs cut and taped in place to get an idea of what it will look like.
Made a mount for the radio antenna
Installed the doors.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:20 pm, edited 1 time in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sat Dec 13, 2014 10:44 pm
Panelling going in.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:21 pm, edited 1 time in total.
Tommy2tone_1999
Postby rebapuck » Sun Dec 14, 2014 2:46 pm
I like the idea of the slide bolt on the cooler...but what will keep it from vibrating open?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby Tommy2tone_1999 » Mon Dec 15, 2014 2:49 pm
I believe so. The bolt fits snug and does not slide easily. I guess a road test will prove for sure.
Tommy2tone_1999
Postby Tommy2tone_1999 » Wed Dec 17, 2014 9:57 am
Finished my second build before I finished the first.
Tommy2tone_1999
Postby KCStudly » Wed Dec 17, 2014 11:22 am
Sweet! :thumbsup:
Postby S. Heisley » Wed Dec 17, 2014 7:24 pm
Your build is coming along very nicely, Tommy. :thumbsup:
