Ok here we go...PMF!
Re: Ok here we go...
Postby Sheddie » Mon Dec 01, 2014 7:54 pm
Jeez KC, that's getting a bit techo for us Kiwis. Down here if you can't fix it with a bit of no.8 fencing wire it ain't worth fixin. :hammer:
:beer: Frank.
Sheddie
Images: 1129
Postby KCStudly » Mon Dec 01, 2014 8:14 pm
Roll that fence wire into a spring and you are good to go! :R
Postby dales133 » Mon Dec 01, 2014 11:52 pm
Lol thanks kc and Yea when I was a kid hardware shops probably sold more miles of number 8 wire than we had miles of roads... the duct tape of the 70 lol
dales133
Postby dales133 » Mon Dec 01, 2014 11:54 pm
I was thinking I might assemble the walls and add sections of foam then slice it once it's glued in situ
dales133
Postby dales133 » Thu Dec 04, 2014 12:54 am
ok heres the shoping from my trip the otherday
made it home in one peice
25 and 35mm foam
dales133
Postby dales133 » Thu Dec 04, 2014 2:19 am
i also just paid for my doors from littleguy, 980 bucks after foreign exchange charges, exchange rates and other bastards taking thier bit of my hard earned money, littleguy wernt to bad at 729 delivered its all the banks having thier pound of flesh.
so i sealed then put the first 2 coats of poly on the inside wall plys, and an initial coat of sealer and one coat of polyon the underside of the floor.
im working the next 4 days thus far but should be making saw dust soon.
i still realy need to get some proper plans but what is the usual front roof radius and set back of the door opening generaly?
dales133
Postby Sheddie » Thu Dec 04, 2014 3:53 am
Hi Dale,
Good to see progress. :thumbsup:
One way to get a rough position for your door openings is to go and lie on your bed. Then sit up and swing your legs out and measure how far from the headboard you are sitting. Then you need to look at approximate axle position for your balance and make sure the doors will clear your guards.
As for the curve on the front, whatever looks good to you. 8)
:beer: Frank
Sheddie
Images: 1129
Postby dales133 » Thu Dec 04, 2014 4:23 am
Sheddie wrote:Hi Dale,
Frank
Thanks Brian.
Got a few surprises up my sleeve for you guys yet ..... the gaurds will work in the position there at almost regardless of the door position and I have no issue with gaurds entering the cabin space.
It's more I've been so busy with the usual work rush before Xmas I'm not realy dedicating the time or head space to the design and build as I'd hoped prior to the "unfortionate religious interuption" that means everything is closed when I get to stop and think for 5 mins without phone calls and interuptions. I'd like th cut the front curve and door hole though.
Then it looks like I've made progress
dales133
Postby dales133 » Mon Dec 08, 2014 3:54 am
finaly made some sawdust!
i need to add 300 mm or a foot and a bit to the hatch end but i haven't picked up the ply for it as yet.
dors arive any day and so do my lights, water filler and fantastic fan ect.
ive also got the iner flooring witch im going to use floating laminate floor but probly glue it down.
its wider than a 4 foot sheet so i thought id use this instead as it was on sale
dales133
Postby Plainsgirl » Thu Dec 11, 2014 3:17 am
Dale did you get your fan from the US? How much? Ta.
Plainsgirl
Postby dales133 » Thu Dec 11, 2014 3:32 am
Not yet but my doors arived today! Just checked tracking on the fan and it's been through customs earlier today and is in transit to international destination [WHITE SMILING FACE]
Cost wise it was about 137 us plus 50 us shipping.
I'll send you a message with the sellers details when it arives if you like.
Pretty prompt service
dales133
Postby Sheddie » Thu Dec 11, 2014 5:16 am
Doors. :woohoo:
:beer: Frank
Sheddie
Images: 1129
Postby Plainsgirl » Thu Dec 11, 2014 5:26 am
Dale did you get your doors from the US as well? I'm a bit surprised by the price of doors here in Aus.
Plainsgirl
Postby dales133 » Thu Dec 11, 2014 5:40 am
Yea from little guy.about 760 us I think for a pair including shipping.
No way I'm gonna pay Dunn and watson almost 1400 for them
dales133
Postby Plainsgirl » Thu Dec 11, 2014 3:10 pm
Thanks brah, AGREED. I also love the stabilizer thingos for your trailer. I haven't seen mine in in the flesh (in the steel?) ..they are the old scissor-lift lookalikes and I hope they are still awesome. I can't tell from the photo. I pick up the chassis in early Jan. CAN'T WANT TO GET STARTED!!
Plainsgirl
