Sheddie wrote:Hi Dale,
Good to see progress.![]()
One way to get a rough position for your door openings is to go and lie on your bed. Then sit up and swing your legs out and measure how far from the headboard you are sitting. Then you need to look at approximate axle position for your balance and make sure the doors will clear your guards.
As for the curve on the front, whatever looks good to you.![]()
Frank
