PA Wilds 16 x 7 x 7 Bug Out Aluminum Trailer
Postby outsidezion » Sat Dec 06, 2014 1:39 pm
After many months of research, goal setting, and compromise, our 16x7x7 aluminum trailer is finally here.
IMG_20141206_112022 (640x480).jpg (116.09 KiB) Viewed 8103 times
IMG_20141206_112008 (640x480).jpg (147.02 KiB) Viewed 8103 times
IMG_20141206_111935 (640x480).jpg (155.23 KiB) Viewed 8103 times
More pics from dealer here: https://www.facebook.com/media/set/?set=a.584587601673540.1073741889.384373461694956&type=1
We worked with Justin at http://www.northpoint-auto.com/. Great guy, great outfit. Ultimately, we ended up buying way more trailer then initially planned.
However, an all aluminum trailer should last a lifetime and is a delight to tow.
Based on what we learned about ATC trailers, we opted for factor insulation and wiring and LED lighting and the factory install is topnotch. Also, we upgraded doors, windows, fantastic fan and others. Buy the time I would option all and install them myself, we weren't much further behind financially to end up with an integrated, factory-installed approach.
Lots more to come as the project progresses.
PA Wilds Bug out Trailer 16 x 7 x 7 Aluminum: http://www.tnttt.com/viewtopic.php?f=42&t=61833
outsidezion
Re: PA Wilds Bug Out Trailer 16 x 7 x 7
Postby outsidezion » Sat Dec 06, 2014 1:46 pm
Poly'ed the walls and floor:
IMG_20141206_112102 (480x640).jpg (95.97 KiB) Viewed 8101 times
Previously, I started work on a 3-stack drop-down bunk bed for the kids:
IMG_20141206_112145 (640x480).jpg (125.76 KiB) Viewed 8101 times
outsidezion
Postby outsidezion » Sat Dec 06, 2014 1:48 pm
And a pile of goodie's waiting to go in:
IMG_20141206_115545 (480x640).jpg (128.53 KiB) Viewed 8099 times
IMG_20141206_115529 (480x640).jpg (106.89 KiB) Viewed 8099 times
outsidezion
Postby outsidezion » Sat Dec 06, 2014 1:49 pm
IMG_20141206_120047 (480x640).jpg (121.11 KiB) Viewed 8099 times
IMG_20141206_120042 (480x640).jpg (57.52 KiB) Viewed 8099 times
outsidezion
Postby Prem » Sun Dec 07, 2014 11:51 am
:applause: Excellent trailer! Congrats. :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby lrrowe » Sun Dec 07, 2014 12:08 pm
Nice choice.
Bob
lrrowe
Images: 439
Postby outsidezion » Sun Dec 07, 2014 12:32 pm
I had the great privilege of lurking here on this forum for many months which significantly shaped my decision. We wanted a true multi-use unit, low fuss (no full-on RV build here) but with some practical amenities.
More to come as we spec it out. And thanks to all those who have gone before - what a great resource!
outsidezion
Postby Spotman » Sun Dec 07, 2014 2:17 pm
outsidezion, REALLY NICE TRAILER AND MATCHING TOW VEHICLE. LOOKING TO SEE YOUR MODIFICATIONS. :thumbsup:
Bob
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
Postby abqlloyd » Sat Dec 13, 2014 1:27 am
Nice looking trailer.
abqlloyd
Postby bc toys » Sat Dec 13, 2014 10:33 am
Nice trailer but you might want to box battery in and add a vent to outside for it
bc toys
Images: 42
Postby Rainier70 » Sat Dec 13, 2014 11:45 am
I don't know for sure what kind of battery you have, but if it needs venting, here is an example of a vented battery box:
Rainier70
Images: 244
Postby outsidezion » Sat Dec 13, 2014 3:48 pm
[quote="Rainier70"]I don't know for sure what kind of battery you have, but if it needs venting, here is an example of a vented battery box:
Thanks for the heads up. There is warning notice riveted right next to the battery that advised it is sealed and safe for indoor use and that any replacement must follow the same protocol.
outsidezion
Postby outsidezion » Sat Dec 13, 2014 3:55 pm
Flip-down bunk beds have been installed for the kids:
Bunk 1.jpg (96.34 KiB) Viewed 7725 times
Bunk 2.jpg (104.24 KiB) Viewed 7725 times
Bunk 3.jpg (113.65 KiB) Viewed 7725 times
outsidezion
Postby abqlloyd » Sat Dec 13, 2014 3:56 pm
Better patent that design. Pretty ingenious.
abqlloyd
Postby outsidezion » Sat Dec 13, 2014 3:57 pm
Bunk 4.jpg (92.71 KiB) Viewed 7722 times
Bunk 5.jpg (98.2 KiB) Viewed 7722 times
outsidezion
