After many months of research, goal setting, and compromise, our 16x7x7 aluminum trailer is finally here.
- IMG_20141206_112022 (640x480).jpg (116.09 KiB) Viewed 8108 times
- IMG_20141206_112008 (640x480).jpg (147.02 KiB) Viewed 8108 times
- IMG_20141206_111935 (640x480).jpg (155.23 KiB) Viewed 8108 times
More pics from dealer here:
https://www.facebook.com/media/set/?set=a.584587601673540.1073741889.384373461694956&type=1We worked with Justin at
http://www.northpoint-auto.com/. Great guy, great outfit. Ultimately, we ended up buying way more trailer then initially planned.
However, an all aluminum trailer should last a lifetime and is a delight to tow.
Based on what we learned about ATC trailers, we opted for factor insulation and wiring and LED lighting and the factory install is topnotch. Also, we upgraded doors, windows, fantastic fan and others. Buy the time I would option all and install them myself, we weren't much further behind financially to end up with an integrated, factory-installed approach.
Lots more to come as the project progresses.
