What type/thickness mattress do you use
Postby dales133 » Sat Dec 06, 2014 6:54 pm
Just wondering what your mattress style and thickness preferences are.
There are plenty avaliable here in the 200 mm or 8 inch range but I'm mind full of taking up to much interior hight
dales133
Re: What type/thickness mattress do you use
Postby ddrabant » Sat Dec 06, 2014 7:06 pm
I played around with several configurations .. what works for my wife and myself is a 8"memory mattress with a futon mattress on top of it.. we found that memory foam by themselves just don't breathe well enough . ours are queen size..
ddrabant
Postby gudmund » Sat Dec 06, 2014 7:20 pm
started with the W-M 4 inch Memory foam (2 inch foam/2 inch rubber) than added 2 half inch layers of the rubber floor pads which if needed would also work for laying on for road fixes/kneeling pads if needed. Have since added another W-M memory foam pad 1.5 thick for a total of 5.5 inches of foam + 1 inch rubber. Seems to be OK now, not so much rolling any longer in the nite anymore. Probably should have just had a real mattress made to begin with looking at what it has all cost so far.
gudmund
Images: 39
Postby dales133 » Sat Dec 06, 2014 7:52 pm
That's part of my concern, ending up paying to much after experimenting and still ending up around 8 inch thick.
How do you find the head room sitting up with 8 inch mattress and what's your door hight like with this? Cheers dale
dales133
Postby dales133 » Sat Dec 06, 2014 7:56 pm
This one dosn't look to bad and has pocket springs
http://m.ebay.com.au/itm/390713414378?nav=SEARCH
dales133
Postby Woodbutcher » Sat Dec 06, 2014 7:57 pm
Mine is 8" and works great. First one was 5"...not enough.
Woodbutcher
Postby kayakdlk » Sat Dec 06, 2014 9:08 pm
5" foam with 1.5" memory foam topper. I usually sleep on top of the sleeping bag in the summer and it works fine.
Dan
kayakdlk
Images: 392
Postby GuitarPhotog » Sun Dec 07, 2014 2:32 am
My teardrop has a 5" medium density foam pad mattress and I've been relatively happy with it even for extended (3-week) trips. My standy has a 3" memory foam topper bonded to a 5" foam pad and I like it much better. So much so that I'm going to have one made like it for my home bedroom.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby coyote » Sun Dec 07, 2014 10:22 am
We got 5 inch foam, cut for us, from the local fabric supply store ( Joann's) 2 pieces, 2 feet wide, 6 Feet long. We love it. Better than the "real" bed in the house. With the shape (Grueman) of our trailer, the height actually raises me up that I gain a few inches length. Plus, setting in the door....best chair in the place! Sorry, no visual, but looking at that profile, you'd see.
coyote
Titanium Donating Member
Postby ae6black » Sun Dec 07, 2014 10:35 pm
Mine is only four inch and I get a better night sleep on it than I do with my fancy mattress at home. Longest I ve ever slept on it was five nights in below freezing temps during hunting season. Never bottomed out or felt cold from below. I rarely use a slepping bag just sheets and a couple of blankets.
ae6black
Images: 19
Postby Backroads4me » Mon Dec 08, 2014 12:19 am
We bought our plain Queen size Verlo mattress from our teardrop manufacturer (TCTeardrops) and just love it. Super comfortable, very well made and it can be folded for removal from the trailer. I bought a moisture resistant mattress cover (from another source), and made a heavy denim covering to place over that. We use a folded out sleeping bag and a comforter for the bedding. Everything easily machine washable. The following info is from TCT's website. There just happens to be a Verlo factory store in the same town and this is what TCT charges for these---specially made for their teardrops. There's other Verlo factory stores in other states.
***Full Size Verlo Mattress: $216. The full size Verlo Mattress is designed to fit the 4'x8' model TCTeardrops. Dimensions: 46"Wx74"Lx5"H
***Full Size Pillow Top Mattress: $350. Add a layer of Gel Memory Foam to the standard Full Size Verlo Mattress. Fits 4'x8' Teardrops. Dimensions: 46"Wx74"Lx7"H
***Queen Size Verlo Mattress: $264. The queen size Verlo Mattress is designed to fit the 5'x8', 5'x9' or the 5'x10' TCTeardrop models. Dimensions: 58"Wx74"Lx5"H.
***Queen Size Pillow Top Mattress: $424. Add a layer of Gel Memory Foam to the standard Queen Size Verlo Mattress. Fits the 5'x8', 5'x9' or 5'x10' Teardrop models. Dimensions: 58"Wx74"Lx7"H.
***Full Size Mattress Cover: $60. Protect and warranty your mattress by adding a cover that surrounds your entire mattress! These covers are very soft and breathable, plus they come with a zip-off top for easy laundering.
Deb
Backroads4me
Postby Backroads4me » Mon Dec 08, 2014 12:30 am
I forgot to add----
Under the mattress is a piece of white, sturdy Styrofoam, about 2 inches high---to raise the mattress up off the floor. I was having trouble getting in and out of the trailer---the bottom door frame was putting bruises on the back of my knees as I struggled to get out the door. :thumbdown: Todd from TCT offered to put the Styrofoam under the mattress---problem solved! :thumbsup:
Deb
Backroads4me
Postby dales133 » Mon Dec 08, 2014 2:17 am
This has turned out to be a great thread and provided alot of ideas sinarios.
I'm gonna get a little off topic but still on the same trail so to speak....it's been mentioned that mattress hight in relation to door hight and I'm also mind full of headroom.
I cut out my sidewalls today following the generic benroy plans except mine is a fair bit longer and wider so I have no issue with side intrusion from wheel arches but the benroy plans say 2x1 floor joists where I've gone for 35mm witch is just under 1 and a half.
So 150mm or 6 inch is the hight from the sheet bottom to the door cut out....is this what you've used and does it work in relation to the mattress.2nd point is with the roof spars around the same thickness and 5 to 8 inch matteress how's the headroom sitting up
dales133
Postby b.bodemer » Mon Dec 08, 2014 8:19 am
I had a door jam of 4" in one td and went with an 8" memory foam.
The other had a 3" jam so I went with a 6" mattress.
Both gave me a great night sleep. Ordered through Walmart with free shipping to either home or store.
Barb
b.bodemer
Images: 328
Postby dales133 » Mon Dec 08, 2014 3:17 pm
b.bodemer wrote:I had a door jam of 4" in one td and went with an 8" memory foam.
Barb
So ideal you recon jam hight half the matteress thickness?
I'd guess the door jam dosn't cut into your legs to much getting in and out
dales133
