air conditioners?
air conditioners?
Postby martymcfly » Thu Dec 11, 2014 1:24 pm
I have only seen people use window ac in their teardrops. Why haven't I seen anybody use one of these? http://www.compactappliance.com/EdgeSta ... fgodkkkAHQ Could you run the big hose out the floor? Maybe use pvc with a screw cap or something when not in use? Easily remove when you don't need it? Is it because this style costs a little more?
martymcfly
Re: air conditioners?
Postby SkipperSue » Thu Dec 11, 2014 2:49 pm
That's a lot more BTU's than you need, the small 4k window units are really too much.
Skipper
SkipperSue
Images: 114
Postby Vedette » Thu Dec 11, 2014 3:08 pm
Too Big!
But there has to be a perfect solution somewhere???? :worship:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby rowerwet » Thu Dec 11, 2014 7:01 pm
There is, for a ton of money, there are marine units, and also for $$$ small units meant for 18 wheeler cabs. It is all about what you want to spend.
rowerwet
Images: 521
Postby HarryL » Thu Dec 11, 2014 7:19 pm
Hi, I'm new here , but have been building a "standy" which I started last Spring. It's built, waiting for Spring to come, but still needs final finish, galley and trim. I purchased ClimateRight's 2500 btu air conditioner/heat pump when they became available last May. I know it's very expensive, but with the heat pump feature I figure it solves two problems at once. It will be mounted at the front of the camper in a storage box.
Also, the 2500 btu capacity of the air conditioner means the unit should run efficiently, drying out the camper without excessive cooling.
I've been a long time lurker and have learned a ton following everyone's builds! 8)
HarryL
Postby Vedette » Thu Dec 11, 2014 8:55 pm
rowerwet wrote:There is, for a ton of money, there are marine units, and also for $$$ small units meant for 18 wheeler cabs. It is all about what you want to spend.
So what brand????
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Shadow Catcher » Thu Dec 11, 2014 9:51 pm
Postby rand_98201 » Fri Dec 12, 2014 2:03 pm
I was thinking about this because its heat and ac in one and can be mounted to the outside on the tongue.http://www.climaterightair.com/applicat ... ating.html
rand_98201
Postby LWW » Fri Dec 12, 2014 9:46 pm
Mr McFly. The air conditioner in your first post really is a flop any where you put it. We bought one and used it on a boat when they first came out and found that the hose you see really radiates more heat than the air conditioner part can over come on a hot day. Please don't buy one.
I used a small 4000 btu room size ac on my weekender and use a small ceramic heater for heat. Less money outlay and simple.
Larry
LWW
