Budget Build For Boo!
Re: Budget Build For Boo!
Postby fullon627 » Wed Jan 07, 2015 8:32 am
I can see all the images in my gallery and my post. Still don't know whats wrong.
It's a great world if you don't weaken!
Boats float and airplanes fly!
If you boat sinks you can swim!
If you airplane falls you can't fly!
Ken from Eureka Ca.
Boo's Build viewtopic.php?f=50&t=60867
fullon627
Images: 283
Postby bobhenry » Wed Jan 07, 2015 10:28 am
Postby KCStudly » Wed Jan 07, 2015 11:06 am
Seems to be all fixed now. :thumbsup:
Postby hmikey » Wed Jan 07, 2015 10:37 pm
I can see your photos fine now, great job, I thought it was my computer that wasn't playing by the rules. Good to see you back.
hmikey
Postby fullon627 » Fri Jan 09, 2015 11:13 am
hmikey wrote:I can see your photos fine now, great job, I thought it was my computer that wasn't playing by the rules. Good to see you back.
I didn't fix it. I didn't do anything. It just started working again??? Unless a administrator fix it? Just glad it's working now. Thanks people.
Ken from Eureka Ca.
fullon627
Images: 283
Postby fullon627 » Tue Jan 13, 2015 1:01 pm
Boo painted two coats on for the stripe. Then she painted one coat of the green. One more coat of green and the trailer goes back on the frame for good!!
Ken from Eureka Ca.
fullon627
Images: 283
Postby fullon627 » Fri Jan 16, 2015 2:06 pm
Boo did the final coat of green, then pulled off the tape two days later. She did a great job!
Boo being proud of her work!
Boo had these earrings made by a woman up in Oregon. The woman thru in a necklace for free!
Ken from Eureka Ca.
fullon627
Images: 283
Postby fullon627 » Sat Jan 17, 2015 10:04 pm
So what do you think about the paint scheme? I personally would have left it all blue, or any other solid color with the lightning bolt she originally designed. But it's Boo's trailer, so she gets to do anything she wants. Instead of aluminum rims that I was going to use, I think I'll go with painted rims that match the stripe with baby moons (maybe even whitewall tires!).
Ken from Eureka Ca.
fullon627
Images: 283
Postby S. Heisley » Sun Jan 18, 2015 10:06 pm
It looks just fine! You all are doing a nice neat job on this rig. :thumbsup:
Keep going! :applause:
PS. Nice jewelry, too!
Postby fullon627 » Tue Jan 27, 2015 12:47 am
S. Heisley wrote:It look just fine! You all are doing a nice neat job on this rig. :thumbsup:
Thanks' Sharon!
Ken from Eureka Ca.
fullon627
Images: 283
Postby dales133 » Tue Jan 27, 2015 12:56 am
Colour scheme looks great as does the graphic design
dales133
Postby fullon627 » Tue Jan 27, 2015 12:59 am
We were just going to spot paint the trailer frame where my son did some new welding but decided it was easier just to paint the whole frame again. We will be setting the trailer on the frame in the next couple of days.
Ken from Eureka Ca.
fullon627
Images: 283
Postby fullon627 » Tue Feb 03, 2015 12:55 pm
Haven't put the trailer on the frame yet. Forgot about painting the edge of the plywood under the lift. So we picked up the trailer by the window and door openings. We made the cutouts of the windows and doors the same height for just this purpose. We picked it up there before when we put it on the lift with the wood cross members. So boo and Mara finally painted the doors their two coats of the blue. They also painted the underside edge of the plywood. Oil based enamel takes a long time to dry in this region, so that is setting us back a few days. Just reserved a site for the "Dam Gathering" on April 30th, so that means that we need to get this trailer done!
Trailer on the wood cross members
Trailer held up by the openings.
Bottom edge of plywood primed and painted.
Boo painting the doors, Mara helped also.
Doors painted.
Boo and Mara excited about Boo's trailer!
Ken from Eureka Ca.
fullon627
Images: 283
Postby fullon627 » Mon Feb 09, 2015 12:58 am
Finally put the trailer back on the frame today for good. It was just Boo and I today. So we put black silicone around the outside edge of the trailer frame before we set it down. Just to waterproof even more the edge of the plywood. Then we put the doors on so Boo could continue her stripe. Once she put the tape on, she back painted the tape with the light blue, to keep the next coat of darker blue from bleeding.
Ken from Eureka Ca.
fullon627
Images: 283
Postby The Teardrop Nanny » Mon Feb 09, 2015 10:40 pm
:D And now you'll be building your own.....Teardrop Fever! The cure is in your hands, literally, Ken. Nicely done, Boo. Looking forward to seeing it completed and camping with you.
Joanie
TDN :R
The Teardrop Nanny
Teardrop Muse
