Haven't put the trailer on the frame yet. Forgot about painting the edge of the plywood under the lift. So we picked up the trailer by the window and door openings. We made the cutouts of the windows and doors the same height for just this purpose. We picked it up there before when we put it on the lift with the wood cross members. So boo and Mara finally painted the doors their two coats of the blue. They also painted the underside edge of the plywood. Oil based enamel takes a long time to dry in this region, so that is setting us back a few days. Just reserved a site for the "Dam Gathering" on April 30th, so that means that we need to get this trailer done!
Trailer on the wood cross members
Trailer held up by the openings.
Bottom edge of plywood primed and painted.
Boo painting the doors, Mara helped also.
Doors painted.
Boo and Mara excited about Boo's trailer!
It's a great world if you don't weaken!
Boats float and airplanes fly!
If you boat sinks you can swim!
If you airplane falls you can't fly!
Ken from Eureka Ca.
Boo's Build
viewtopic.php?f=50&t=60867
