Wall edge rabbiting
Wall edge rabbiting
Postby Diemjoe » Thu Jan 22, 2015 9:41 pm
Some build photos have a lip routed along the Wall roof edge but not all. I plan to do this for mine. Any considerations on how deep is the rabbit should be? Does the inside ceiling rest on the lip then the spars spaced out on top of that then the outside roof? My design is woody but haven't decided on the aluminum or wooden roof yet. Thanks
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: Wall edge rabbiting
Postby backstrap bandit » Thu Jan 22, 2015 9:52 pm
Personally I wouldn't go any deeper than 1/4 inch on 3/4 sidewalls
backstrap bandit
Images: 15
Postby tony.latham » Fri Jan 23, 2015 1:35 am
Don:
I use the sandwich method of wall building and the shelf the ceiling fits on is the depth of the wall minus the 1/4" plywood that is the outside sheathing.
And yep, the ceiling sits on the ledge.
The spars are added...
And blocking between the spars:
Postby dales133 » Fri Jan 23, 2015 2:07 am
Is that in the Fredrick plans aswell tony?
Is you wall frame stick frame?
dales133
Postby Diemjoe » Fri Jan 23, 2015 2:29 am
That's some sweet cable management Tony. Thanks for posting the pics.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Postby tony.latham » Fri Jan 23, 2015 1:44 pm
dales133 wrote:Is that in the Fredrick plans aswell tony?
Yes and yes*. I wish my English tests were that easy back in high school.
*Actually the last photo is of a 4x8 I built using the sandwiched construction that uitlizes skeletonized sheet of 1/2" AC for the guts of each wall (CDX plywood too junky for this). I find this method to be quicker than 1x4"s but more expensive, especially if you're building a 10' long teardrop, since you need three sheets of plywood. Here's it's "guts."
T
Postby dales133 » Fri Jan 23, 2015 4:40 pm
Thanks again tony, I'd take you fishing and buy you a beer or 3 if you were closser
dales133
