How to fix galley hatch notch that was too deep
Postby backstrap bandit » Tue Jan 27, 2015 8:11 pm
Was wondering if anyone has cut the galley hatch notch and it ended up too deep how did u fix it
backstrap bandit
Images: 15
Re: How to fix galley hatch notch that was too deep
Postby KCStudly » Tue Jan 27, 2015 10:23 pm
Becky (Oldragbaggers) had that problem on her "Lance and Becky's Sagwagon ".
She is well experienced with fiberglass and epoxy products and used that to build the edges of her walls back up.
Postby backstrap bandit » Wed Jan 28, 2015 5:25 am
Thanks kc study but her fix won't work for me I have aluminum sides and it too has been cut. Thinking I may put shim under hindge of hatch or build up notch area a little and build down overhang on hatch a little to fill in but need trim to cover shim pieces any ideas for those
backstrap bandit
Images: 15
Postby backstrap bandit » Wed Jan 28, 2015 5:49 am
I did find some D epdm seals that will seal gap but need trim to cover area
backstrap bandit
Images: 15
Postby grant whipp » Wed Jan 28, 2015 11:54 am
backstrap ...
... What is your construction and how thick are your galley walls? Is the aluminum skin already on? Pics and more info would help a lot ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby backstrap bandit » Wed Jan 28, 2015 8:15 pm
Benroy galley walls 3/4 aluminum on gap is between 1/2 to 5/8 after reading another post I think I know where the screw up happened the notch was cut when walls were cut as per plans so roof ply increased it another 1/4 or 5/16
backstrap bandit
Images: 15
Postby backstrap bandit » Wed Jan 28, 2015 8:19 pm
That's the only pic I have of hatch shut at the moment I will take some better ones soon
backstrap bandit
Images: 15
Postby Micro469 » Thu Jan 29, 2015 11:44 pm
Add an aluminum strap to the underside of your hatch to correct the gap size. Then install your weatherstripping.
John
Micro469
Images: 382
Postby backstrap bandit » Fri Jan 30, 2015 5:31 am
Micro doing the strap on the hatch and wall profile was the only way I can think of doing it and then put on trim hopefully the trim will hide the strapping
backstrap bandit
Images: 15
