Pace America 7x12 Build in Seattle
Re: Pace America 7x12 Build in Seattle
Postby McDave » Fri Feb 06, 2015 7:06 pm
Thanks for the info.
McDave
McDave
Images: 412
Postby RVServiceGuy » Fri Feb 06, 2015 9:39 pm
No worries. If you have questions about major rv gear hit me up. Just my personal experience. The domestic toilets are way easier to maintain. Hate to sound like an advertiser but dometic makes a lot of user friendly and decent stuff for travel trailers
RVServiceGuy
Postby RetchedOne » Tue Feb 10, 2015 7:00 pm
Got some insulation installed this weekend, Started removing the floor.
What it started as -
Inside wall before (Small).jpg (73.6 KiB) Viewed 2362 times
The 3/8th stuff removed -
Inside wall stripped 2 (Small).jpg (107.63 KiB) Viewed 2362 times
Trimmed the edge to slide behind the Z Strip -
Insullation edge (Small).jpg (69 KiB) Viewed 2362 times
Once electrical is routed, i will foil tape and foam all the seams.
RetchedOne
Images: 9
Postby RetchedOne » Tue Feb 10, 2015 7:02 pm
Another view of the edge -
Insullation edge 2 (Small).jpg (40.35 KiB) Viewed 2362 times
Inside wall insulated (Small).jpg (128.11 KiB) Viewed 2362 times
Inside view before (Small).jpg (99.55 KiB) Viewed 2362 times
RetchedOne
Images: 9
Postby RetchedOne » Tue Feb 10, 2015 7:03 pm
Just couldn't wait, so I removed one floor board -
Inside view Floor (Small).jpg (100.42 KiB) Viewed 2362 times
Probably wont get back to the trailer till teh 22nd, as Valentines day does not equal trailer time...
RetchedOne
Images: 9
Postby RetchedOne » Tue Feb 10, 2015 7:07 pm
Ordered my windows today from Frank
The kitchen (Sink area) will have a 21 x 14 (front right of trailer)
A 24 x 20 near teh rear right side
A 14 x 21 in the door
Another 24 x 20 in the rear wall (behind the fold up gate)
Hope to have them in by early March,.
For the inside, i will be using a Pre-Finished 5/16th maple.
RetchedOne
Images: 9
Postby bc toys » Wed Feb 11, 2015 11:01 am
:thumbsup: like you work with your trailer
bc toys
Images: 42
Postby Rocky5000100 » Wed Feb 11, 2015 11:11 am
Nice progress. So is your plan to install the insulation boards first, then cut out grooves/channels for the electrical? I'm still debating how I'm going to do it.
Rocky5000100
Postby RetchedOne » Wed Feb 11, 2015 12:00 pm
Once I finalize where electrical goes I will use my dremel to zip paths through the insulation (1/4 inch deep) to the top of the trailer through a grommet in the metal "header". Smurf tube hidden in the arch of the roof will run back to the PD4045 the rear.
I'm still trying to visually layout what I need where, and what will be used.
So far I cant fit a 4k UHD tv anywhere that looks good...
RetchedOne
Images: 9
Postby Rocky5000100 » Thu Feb 12, 2015 6:24 pm
Good idea with the dremel bit. I will have to remember that.
Rocky5000100
Postby craigatx » Fri Feb 13, 2015 12:22 am
I'm curious about that sound deadener. Do you really get 40 sq. ft. of coverage from one gallon?
craigatx
Postby lrrowe » Fri Feb 13, 2015 10:33 am
RetchedOne wrote:Ordered my windows today from Frank
RetchedOne,
Please tell me more on the 5/16 Maple. Are you usingI 4x8 sheets or strips?
Bob
lrrowe
Images: 439
Postby RetchedOne » Fri Feb 13, 2015 10:55 am
RetchedOne,
Hey Bob,
The 5/16th Maple comes in a 4x8 sheet that is pre-finished in a clear coat of lacquer over a maple veneer.
It's used in cabinets all the time.
I figured since I was going to use 1/4 inch on my interior walls and then do something for "color" that this saves me a step or two.
I'll snap a few pictures of the product this weekend.
-Aaron
RetchedOne
Images: 9
Postby lrrowe » Fri Feb 13, 2015 11:03 am
Great Aron. I look forward to it. I am wrestling with something like that or go with a hickory or pine strips. I like the wood effect and would paint our cabinets a muted green color for contrast.
Bob
lrrowe
Images: 439
Postby RetchedOne » Mon Mar 30, 2015 3:02 pm
Sorry for teh long delay, got sick, then life got busy... Were moving in a few weeks so I have to get the trailer somewhat ready to use to haul our crap to the new place. I'm in teh process of re-wirign the actual trailer lights with new LED lights and break away controller.
I did get the new 3/4 inch plywood flooring in and secured... Painted the underside with a exterior paint to seal it up a bit.
open floor.jpg (73.7 KiB) Viewed 1961 times
Here's the Pr-Finished 5/16ths material that will be used for the walls.
A few more interior pics
ceiling insullation.jpg (49.35 KiB) Viewed 1961 times
RetchedOne
Images: 9
