Professors 7x14 Toy Hauler
Re: Professors 7x14 Toy Hauler
Postby zroadhouse » Sat Feb 28, 2015 11:48 am
Looks great! I will be drawing on your thread when I get to my upper cabinets and kitchenette!
zroadhouse
Images: 103
Postby professorkx » Mon Mar 02, 2015 2:14 pm
The trailer is essentially finished and ready to be used. This past weekend, I finished all of the final items in order to use the trailer.
I started by making the piece that fits above the rear doors. Once again, I used my marking gauge to cut the curve of the roof and attached to the frame.
The trim piece from the ceiling to the walls gave me fits, and I had trouble finding something I liked. In the end, I purchased a 51 foot roll of 7" roof flashing from Home Depot for just over $30 to use to build trim pieces. I started by cutting the flashing to length with my chop saw. This throws some metal shavings, and the edges are sharp, so goggles and gloves are a must.
Once a piece was cut to length, I used a 6 foot piece of black sewer pipe I had left over from a remodel, and gently rolled the flashing around the pipe from one end to the other. I had to be careful not to roll to close to the end of the pipe, as this tended to put a wrinkle in the flashing, so I tossed my first attempt. I rolled from one one end to the other to get the curve started, then back again for my final pass.
The flashing is not very thick, so difficult to carry even with the curl, and especially difficult to carry a 14 foot long piece. So, using blue painters tape, I attached a 1x2x8 down the middle of the flashing. I had already marked the ceiling with a pencil for the top edge of the flashing, and the staple gun was standing at the ready. We carried the flashing into the trailer, my wife helped hold it in place and I stapled the top edge to the ceiling about every 10 inches. Once the top was attached, I pushed the flashing up for a tight fit and stapled the bottom to the wall. The last step was to install 1 1/2 inch trim pieces made out of 1/4 inch plywood. The top was painted white to match the ceiling and the bottom was painted gray to match the walls. A few pictures. I should note that the reflection makes it looks like there are creases, but that's just the way the light is hitting the aluminum.
The 14 foot piece
The 10 foot piece, both ends
In the bathroom area, I decided I didn't like the rough plywood finish nor the white paint, so I skinned the walls with 1/4 plywood painted gray. This left white in the kitchen and on the ceiling, so I think I have a nice contract throughout the trailer. Final pictures of the entire front of the trailer.
With the interior complete, it was time to add a tongue box, battery and propane tank for the two burner stove. With the stove the only propane item, a small tank should last a very long time.
I selected this tongue box for several reasons:
1. It locks, a must since I am using an Optima group 31 blue top battery that costs $300
2. The propane tank will fit inside with the lid closed and still have about 1/4" to spare
3. The aluminum diamond plate matches the look of the trailer.
One problem I noted was that the jack handle hit the front of the box. So, I removed the handle, drilled out a 7/8 inch nut for a tight fit on the jack shaft and drilled/pinned the nut onto the shaft. This allows me to use either my 12 volt impact I keep in the jeep or a drill adapted to accept a 7/8 socket. Either way, down and up on the jack is pretty quick.
I still need to paint and install a bike shoe so the bike will stay securely in place and we will be ready for our first camping trip, so probably two weeks away. I will post pictures from the first camping trip, as well as the solar in a few months when I install.
I wanted to say thanks to everyone who has posted over the years, many of whom are probably long since gone. I tried to give back by providing detailed instructions on my process. I'm a perfectionist with a lot of different skills, so I probably put more into this trailer than many feel is necessary. However, I believe my conversion shows that just because these are DIY projects, they can still look as good as any factory built trailer.
professorkx
Postby Rocky5000100 » Mon Mar 02, 2015 2:19 pm
I like the roof flashing idea for trim. I may do that instead of putting the Luan back up (though I might not be able too anyways, it cracked when I pulled it off haha)
Or I may go with some preformed aluminum like this
http://m.homedepot.com/p/Fasade-4-ft-Br ... aQod6RIAkw
Rocky5000100
Postby lrrowe » Mon Mar 02, 2015 2:23 pm
professerkx,
What a fantastic job. Your interior is very clean and uncluttered looking. The flashing idea works very well. Painting the bathroom walls was one option I was considering.
Your tongue box fits nice and I might look at one also, but in my case, I believe I will mount the propane tank(s) on a plate next to the box, move the batteries inside and use the box for all the "stuff" that goes with me.
I am looking forward to your future travel posts as I expect they will also be very interesting. Oh and I hate to hand crank my jack so I am going to investigate copying your idea on that.
I have almost all my items order in house (water heater came today) and I hope I can get to being close to as nice as yours.
Bob
lrrowe
Images: 439
Postby professorkx » Mon Mar 02, 2015 6:06 pm
Rocky5000100 wrote:I like the roof flashing idea for trim. I may do that instead of putting the Luan back up (though I might not be able too anyways, it cracked when I pulled it off haha)
I have rounded corners at the roof transition, or I would have opted for a preformed piece. Round roof versus flat roof, one of the many differences when doing a conversion.
professorkx
Postby professorkx » Mon Mar 02, 2015 6:09 pm
lrrowe wrote:I have almost all my items order in house (water heater came today) and I hope I can get to being close to as nice as yours.
Thanks for the kind words. This project took a lot more man hours than I had anticipated, especially those dang windows. I also hate painting, but it seems 1/4 of the man hours was spent painting stuff in the shop before I installed so I didn't have to mess with tape. Tons of work, but now we get to play... :twisted:
professorkx
Postby Wi urban camo » Mon Mar 02, 2015 7:48 pm
Two thumbs up! :thumbsup: :thumbsup:
Think left and think right and think low and think high. Oh, the thinks you can think up if only you try. Dr. Seuss!
Wi urban camo
Images: 6
Location: Somewhere between fields of corn and Metropolis - Wisconsin
Postby hankaye » Tue Mar 03, 2015 11:33 am
professorkx, Howdy;
You've done a great job putting all your ideas into a useable
and easy on the eye "Home away from Home". Thanks for including
us on the journey and taking the time to explain in depth, what
it was that was questioned.
Thanks.
hank
hankaye
Postby Rainier70 » Wed Mar 04, 2015 7:41 pm
Great job! :thumbsup:
I like how you pre-rolled your flashing. My trailer is only 12 ft long and I had a bugger of a time getting my flashing up without kinking it. I loosened my ceiling panels, slid the flash up behind and then pulled it down until it slid into the top of the wall frame. Pre-rolled would have worked so much better.
I also used a piece of 14 inch flashing for above the back doors so I could access the lights there. Did you use flashing on the end or painted plywood?
It looks great!! :applause:
Rainier70
Images: 244
Postby professorkx » Wed Mar 04, 2015 9:17 pm
Rainier70 wrote:I also used a piece of 14 inch flashing for above the back doors so I could access the lights there. Did you use flashing on the end or painted plywood?
I thought about using flashing, but quite frankly, that stuff is just harder to trim than plywood. So, I used my marking tool to get a nice tight fit against the curve of ceiling and just used 1/4 inch plywood. I had some left over from the ceiling, so it was available. I can still access the wiring behind the panel, as the panel is just screwed to the door frame, but I would still have to deal with the caulking. Much like caulking the top edge of the base molding when I remodel, the caulking makes everything look finished, but its a pain to remove.
professorkx
Postby McDave » Sun Mar 08, 2015 6:57 pm
Very nice work!
I'm learning a lot from you folks.
Thank you.
McDave
Images: 412
Postby Prem » Sun Mar 08, 2015 7:06 pm
:thumbsup: Who needs a house with a living space that nice?! :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby aztrooper » Sat Mar 14, 2015 2:44 pm
Great job. I hope mine turns out half as nice.
aztrooper
Postby professorkx » Sat Mar 14, 2015 5:17 pm
took the trailer over to the scale today to get a weight before I install the motorcycle. Total weight was 2800 pounds without the Triumph, so I was successful in keeping the weight down. The tongue weight is the problem, as it was 560 pounds, so I have some work to do to get the tongue weight down to around 350 pounds. I will start by mounting the bike shoe so the motor of the bike is just rear of the center of the axles.
Any other thoughts would be welcomed.
Oh yes, we decided we didn't like the rubber floor in the kitchen area, so I cut it out and replaced with the same indoor/outdoor carpet that I put on the walls. We like it a lot better. I will post pictures later...
professorkx
Postby Spotman » Sat Mar 14, 2015 5:29 pm
Very nice completion, I am sure the family will enjoy for years to come. This will outlast many stick built, plus you have it "your way." :twisted:
Bob
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
