TrailerEd wrote:I have read several discussions here so far on this. By the way, this is an awesome site with wonderful people, loaded with great info! Loving it!!!!
My question is;
If I wanted to build a wooden, structural frame instead of steel (going old school), do you think it is best used on shorter, more localized trips vs. long road trips?
Do you think the long term effects of the hazards of the road will cause damage to the actual wooden frame? Give me your thoughts.
Has anyone done this and what has been your experience?
I have read Mike's Ultra lite design ideas. I would want to have a steel tube tongue. I am thinking half torsion axles as well.
P.S. I am just throwing out a question here as I am researching all kinds of ideas as I think thru what it is I really like and want to try!
Thanks
GuitarPhotog wrote:Just a note here: Wikipedia says that a typical Conestoga wagon weighed about 1300 lbs empty and typically carried 2,000 lbs of cargo.
<Chas>
rowerwet wrote:The big freight wagons like Coors and bud use in the commercials hauled close to 6k.
KCStudly wrote:TD beer wagon? Now you are talking foamie speak! the proverbial 500 lbs of beer ballast.![]()
martymcfly wrote:I just bought a 1977 Vanson boat trailer last weekend for $125. The springs, axle, and fenders are all one piece that is bolted to the boat frame with 5 bolts on each side. A set up like this might lend itself to an application like the pic above posted by Alaskan teardrop. The only problem is that it is 72 inches wide.
rowerwet wrote:I worked on aerobatic aircraft for a while, the top performing aircraft at the time were the Extra 300. They used a wooden spar for the wing, wood will stand up to more repeated flexing loads than the same weight in metal. The aircraft could take 6 g's positive or negative, a real strain on the pilot.
The church I'm the caretaker for has only laminated wood arches to support the roof something like 10 layers of 1x4" lumber, beautiful to look at and much stronger than a truss roof.
A frame built of laminated wood could be lighter and stronger than steel. I would have the frame be the outer corners of the walls, then make the tounge a triangular shape with one arm sweeping up from the coupler flowing into the roof. For even more strength a thin plywood Webb tying the triangle frame together also laminated with marine epoxy.
The bottom two legs of the triangle would flow out and back and graft into the laminated frames making up the perimeter of the walls.
This kind of monocoque construction is what you see in air craft and boats.
