A/C Placement
A/C Placement
Postby jje507 » Sun May 28, 2006 9:04 pm
Hey everybody,
Need some input on my a/c placement. I really don't have room up front, so I'm going to have to put it down by our feet. I'm just wondering about problems with blankets possibly getting in the way of the air return.
Has anyone had these problems and how did you solve them.
Thanks,
Jeff :thinking:
jje507
Images: 16
Postby 48Rob » Mon May 29, 2006 6:25 am
Hi Jeff,
I've not done one "down by our feet", but a simple face extension would allow the air to be drawn from above, instead of in front.
Think snorkel.
Rob
48Rob
Postby Chip » Mon May 29, 2006 6:49 am
Jeff,, Ya could run into a problem if you fully block off the return air side of the a/c,, but its larger than the supply side and if ya mount it up as high as you can in the foot well ya probably will be ok,,, If ya just cant get it up above the blankets ya might try and figure out a baffle that would assure air flow down to the intake,,,
My problem is I have no space for an a/c either in the galley, footwell or headboard area,,, Soooooooo I am trying to "Ignajgeer" another option,,
I might have come upon an idea but its still on scratch paper and I would loose the use of a second door during use,, that is when I get the second door cut in,,, Good luck with getting it worked out,, Summer is definately here,,,
chipper
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby SteveH » Mon May 29, 2006 7:43 am
Jeff,
I know many may not like this for several reasons, but this is how I solved the problem.
SteveH
SteveH
Images: 42
Postby Bandit » Mon May 29, 2006 8:48 am
I am placing my AC unit high in the headboard on a slideout. I purchased a RV hatch door that will be mounted in the front wall. When I get set up, I open the hatch, slide out the AC unit. This also gives me a little shelf in front of the AC unit when setup.
Since I am building a WeekEnder, the front wall is flat and makes this possible. I guess it is more difficult is the curved wall of a TD.
:thumbsup: :thinking:
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby oklahomajewel » Mon May 29, 2006 9:47 am
I don't have mine installed yet, I'm about halfway thru the build -- but I've seen more than one person put it in the cabinet. You know, above your knees. Then put a vent up top or on mine, it will be on the side.
I saw Rickxr2's at Beavers Bend and he mentioned about the air kinda blowing towards their faces at night and was going to put a small little curtain or something to kind of baffle it.
The a/c I already bought, $89 at Lowe's , is 5050 btu and weighs 41 lbs.
This is going to be right above the axle line so I'm sure it'll be fine.
Good luck
Julie
oklahomajewel
Images: 82
Postby john » Mon May 29, 2006 3:47 pm
Mine is mounted on the floor near my feet. When I first used it on our first trip I found that it would cycle off before drying the air. Although the temp got down to the right place, the humidity was still too high (the result of an over sized unit and I had the smallest one I could get). The first night camping an extra pillow made its way down to the A/C. By morning we awoke freezing. I figure the pillow got the efficentcy of the A/C unit down to what we need for the small tear.
i ended up experimenting with the pillow the next day. The worst I could expected from covering the front of the A/C with the pillow was evepoator freeze up. I never saw any ice. (never clog up the condensor side). Ever since this experience we keep an extra pillow in the tear for summer use.
This is just my experience and it worked for me.
My A/C install can be found below.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby kirtsjc » Tue May 30, 2006 6:59 am
john wrote:My A/C install can be found below.
Went to examine details on your A/C, and found lots of other neat stuff instead for my build!
Thanks for being so much more "photo"-oriented than I!!!
:R
kirtsjc
Images: 43
