side to side weight
side to side weight
Postby Getting away with it » Sun Apr 12, 2015 9:06 pm
Does anyone know of a site explains the effects of unbalanced side to side loading? How much is too much, how does it change the handling of the trailer? A 7x12 cargo trailer 4 to 5000 lb weight (7000 cap) about 400 lb imbalance.
Thanks,
Mike :roll:
illegitimi non carborundum
Re: side to side weight
Postby Mike S » Sun Apr 12, 2015 10:06 pm
My off-the-cuff guess is that 400 lbs will make no difference what-so-ever in a trailer that big. If you find a site with good information on trailer balance and/or weight distribution, please share it with us.
2013 7 x 16 Charmac Stealth CT , deep in conversion process :)
http://www.tnttt.com/viewtopic.php?f=42&t=66412
2011 Toyota Tundra, 4x4, Double Cab, 5.7L
Mike S
Images: 54
Postby cornfused » Mon Apr 13, 2015 10:42 am
I doubt it will affect anything as long as your tongue weight ratio is still right. Just make sure not to overload one side. For example, if your trailer axle is rated for 3500lbs, don't put more than half of the rated weigh distributed at one side.
cornfused
