The Poet Creek Express - Foamie Hybrid
Re: The Poet Creek Express - Foamie Hybrid
Postby GPW » Tue Apr 14, 2015 4:33 pm
Since we’re on about this , we just lost our Cat Sam ... 18 1/2 years old ... The old boy just couldn’t go anymore ... Sad to lose our friends , eh KC ...
Postby Atomic77 » Tue Apr 14, 2015 5:06 pm
Sorry about your Maggie... I lost my maggie a year ago... And God brought me a new girl a few months later... I knew she was the one... she already had a name...Maggie.
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby KC's Mom » Tue Apr 14, 2015 5:42 pm
Sending warm wishes and hugs for you guys tonight. It's hard to believe she was almost 10. It seems like only yesterday when you got her.
KC's Mom
Postby daveesl77 » Tue Apr 14, 2015 5:45 pm
KC, I am so sorry for your loss. Pets are family.
dave
daveesl77
Images: 273
Postby KCStudly » Tue Apr 14, 2015 5:52 pm
Thank you all for the well wishes and kind thoughts. They are very much appreciated.
Postby Ned B » Tue Apr 14, 2015 6:06 pm
KC, GPW sorry for both of your losses. our furry family members are such important parts of our lives.
Makes me count my blessings with our pride of 5 felines and our lone, though aging, ball chaser Dachsie/terrier mix.
Ned B
Postby Wobbly Wheels » Wed Apr 15, 2015 8:24 am
So sorry to hear that KC - you too GeeP. I know what a cloud that can cast over one's life.
When I lose a buddy (confessed dog guy here), I try and remember first and foremost that what I'm feeling is a direct result of the good times and positive impact they have on our lives...otherwise it wouldn't be so tough to get over.
It's a crime that their lifespans are so short....but gorillas and elephants make tough pets...
Wobbly Wheels
Postby KCStudly » Wed Apr 15, 2015 8:49 am
Thanks. I appreciate the sentiment.
Postby atahoekid » Wed Apr 15, 2015 10:55 pm
Sorry to hear about the losses KC and GPW, :( I stopped in to look at progress and still (as expected) it is all top notch work. Good to see the progress! :D
Mel
atahoekid
Images: 158
Postby KCStudly » Wed Apr 15, 2015 11:14 pm
Thanks Mel, on both counts.
Got the taxes done, so tomorrow is back to the build.
I found a reasonably nice tension spring in a pile of junk yesterday. It's used and tweaked a little, but still good, so will add that to my hot wire knife before the next use; when ever that may be. Might do a test cut just to see.
I plan on picking away at the hatch wiring details some more and finishing the front foam. I'm going back and forth on whether to mount the hatch handle. I think I would like the look of it, but it is relatively heavy being solid stainless steel; and I have concern about someone yanking on it against the actuators. The actuators won't give like struts, so they will leverage whatever force is applied into the hatch and hinge. I'm probably better off leaving it off. Maybe I'll add the blocking but leave the handle off. :thinking:
Postby GPW » Thu Apr 16, 2015 5:32 am
Just thinking ahead .... actuators.... will there be a way to open the hatch , should the actuators fail ? :thinking:
Postby KCStudly » Thu Apr 16, 2015 6:34 am
Yes. The lower mounts are bolted thru from the cabin side of the bulkhead. Remove 4 bolts with a 1/2 inch wrench and I will be able to lift the hatch manually. I made custom 2-bolt SS washer plates for under the heads of the bolts on the cabin side (although I think I will have Dave powder coat them black like the locker trim so that they disappear more... they kind of stand out inside of the rear cabinet with no doors on them...which also reminds me that I want to have the ceiling outlet cover plate in black, as well).
The upper shelves in the galley will have chases around the actuators. I am also considering filing the detention nubs off of the weather tight electrical connectors, so that they can pull apart if need be, but will take a closer look at that when I do the wiring (if I can create enough slack w/o making an eyesore I would rather not create the possibility for the connectors to separate due to vibration). Maybe I'll wind the pigtail into a curly-Q (like a phone handset cord) to create some extra slack, yet keep things tidy; or even buy some coiled/retracting cable.
Postby OP827 » Thu Apr 16, 2015 10:27 am
I am sorry for your pets losses KC and GPW. I know it is hard, I had a dog and lost him too long time ago, but it was hard.
Great work KC. I want to keep up with your highest level of detail, I shall try. :thumbsup:
OP827
Images: 414
Postby KCStudly » Thu Apr 16, 2015 1:24 pm
Thanks OP.
I do appreciate the sentiment and kind words.
Postby S. Heisley » Thu Apr 16, 2015 5:50 pm
I have a belief that with each step of our lives, we are "given" the pet with the personality that we are needing, if we need a pet. Further, I have decided that the reason animals can't "talk" is because, if they could, they would tell us everything that they know, which is more than we are supposed to know.
Magdalene was a beautiful, interesting looking cat. RIP. Condolences to you, KC. Maybe you'll see her in Kitty Heaven someday.
