Deediggler wrote:I like Sika products. I use Sikaflex 221. It comes in white black and translucent which is great.
Rocky5000100 wrote:Deediggler wrote:I like Sika products. I use Sikaflex 221. It comes in white black and translucent which is great.
Okay. Is that what I'm going to want to install my cargo door with? I keep seeing people talk about butyl tape too.
I was thinking just a thick bead of sealant around the flange, then press it in to place.
nunrleft wrote:You need 10/3. 12 gauge is rated for 20 amps. If you use 12 and are plugged in to a 30 amp supply and draw over 20 amps you run the risk of melting your wires causing a dangerous short or fire.
The 3 at the end of 10/3 is the number of wires in the casing. You need three wires for service; hot, neutral, and ground.
