Bespoked ......
Bespoked ......
Postby trikingtype » Sat Apr 18, 2015 1:29 am
Hi all,
I introduced myself on the Newbie forum (five wheels is the way to go)
I have now almost finished the frame and suspension. The rims are aluminium 18" Weiman BMW, the spokes are s/steel, the hubs are bespoke Triking items. The stub axles are from a Triumph Vitesse mated to 250kg trailer suspension units, the tyres are 400 x 18 Avon SM's.
Now for the body ......
Andy
trikingtype
Re: Bespoked ......
Postby dales133 » Sat Apr 18, 2015 2:37 am
Interesting...like to see how this ends up
dales133
Re: Bespoked ......
Postby trikingtype » Thu Apr 23, 2015 4:24 pm
Hi All,
Test fit of body on frame. I have not decided on mudguards yet or the final shape of the bottom curves.
Andy
trikingtype
Re: Bespoked ......
Postby KCStudly » Fri Apr 24, 2015 8:51 am
Very cool. I would match the front guards on the Morgan TV.
Re: Bespoked ......
Postby dales133 » Fri Apr 24, 2015 7:03 pm
That set up is going to turn some heads going down the road
dales133
Re: Bespoked ......
Postby trikingtype » Mon May 18, 2015 6:50 am
A bit more progress .... Just joint mouldings and door to sort
trikingtype
Re: Bespoked ......
Postby dogscats » Mon May 18, 2015 11:41 am
Great looking
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Re: Bespoked ......
Postby trikingtype » Tue May 26, 2015 1:28 am
Road test completed, tows really well, just need to polish it now !
It has a hinged 'drop down' floor hatch which allows you to sit on the floor, dangle your feet outside and eat at a hinged shelf / table, whilst looking out of the rear window. To prevent it from tipping back I have fitted a telescopic leg at the rear. It also has a solar powered roof vent.
trikingtype
Re: Bespoked ......
Postby dales133 » Tue May 26, 2015 5:21 am
Well done, I love it
dales133
Re: Bespoked ......
Postby Breytie » Tue May 26, 2015 5:37 am
That is so damn neat! They go together perfectly! Very well done!
Where is the :pictures: of the neat features. If there is no pics, it didn't happen!
Experience is learning from your own mistakes
Here I make mine in public: My build
Breytie
Images: 36
Re: Bespoked ......
Postby Sheddie » Tue May 26, 2015 11:22 pm
Wow Andy that is looking the part. :thumbsup: :applause:
You will be really pleased with your self, I bet.
Now you just need to get out and use it. Good luck and post lots of :pictures:
Sheddie
Images: 1129
Re: Bespoked ......
Postby trikingtype » Tue Feb 02, 2016 3:44 pm
Hi All,
Some time since my last post. Done quite a few miles now with no real drama except with the mudguards. I wanted them to hug the tyres so i mounted them on the suspension trailing arms, unfortunately the vibration and suspension movement causes the support brackets to fail. I have reluctantly decided to mount the guards onto the body.
The attached picture was taken at the Brackley Motorcycle festival in 2015
trikingtype
Re: Bespoked ......
Postby Sheddie » Thu Feb 04, 2016 12:21 am
Hi Andy,
great to see you are getting some miles behind you, and enjoying your teardrop. Would love to see more :pictures: of your travels. How is the 3 wheeler handelling it?
Sheddie
Images: 1129
Re: Bespoked ......
Postby Vedette » Fri Feb 05, 2016 1:16 am
Oh Yah!
Way to Cool! :twisted:
Love it, Love it, Love it! :applause:
Well done! :thumbsup: :thumbsup:
Good Roads
Brian & Sandi :wine:
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Bespoked ......
Postby trikingtype » Fri Feb 05, 2016 9:25 am
Hi Frank, Brian, Sandi,
The 3 wheeler has about 70hp and weighs only 390kg, so it doesn't struggle to pull the Pod. There is however an issue with the electrics as I only have 20 amps to play with, I have considered uprating the alternator or fitting LED lights all round. My Triking has no reverse gear which isn't normally a problem, but with the Pod attached ... it is !
Regards Andy.
trikingtype
Users browsing this forum: jdeleon and 3 guests
