Rocky5000100 wrote:nunrleft wrote:
And actually 10-2 and 12-2 do have 3 wires. 10-3 and 12-3 have 4 wires. It's weird haha.
You're correct if you're using solid core wiring. I thought you were using Marine grade stranded wire like I'm using.
bc toys wrote:10/2 or 12/2 is good for what you are using it for need code says 12 is good for 30 amps now 2011 was the change 12/2 comes with ground you can still use a 10/2 SO cable for shore power to be on safe side
Rocky5000100 wrote:And lastly, got the 30 amp shore plug wired up with 10-2 and installed. Question though, is that seal they provided good enough, or should I used some of that sealant I got to make it more waterproof? There is a stress relief cover over the wires not shown in this pic.
LostOne wrote:Rocky
Hoping to draw from your recent experiences.
What are the 'cons' of using OSB for the ceiling panels?
I'm looking to do a more industrial finish, so the OSB wouldn't bother me too much. I'm wandering if the trick of using watered down 'titebond II' as a primer (like they talk about on the 'Foamie forum), would make any sense. Mine will not be a dedicated 'camper either. I've also considered using a sandwich method on the walls, leaving the factory paneling adding 2x2" (stud extension), Insulation between, and then OSB for a liner/interior wall.
By the way I like your build. Very nice.
