Zimmer Wee-Zim [circa 1949?]
Re: Zimmer Wee-Zim [circa 1949?]
Postby bohemian » Tue Apr 21, 2015 5:18 pm
Boy do I have some work to do.
I'll try to get some measurements on my off time, I don't think my client would want to pay me to do the documentation work.
The last pic is the reason we keep an eye on leaks around the galley hinge. :thumbsup:
Wayne
bohemian
Images: 233
Postby S. Heisley » Tue Apr 21, 2015 7:52 pm
:o It looks a lot cleaner and nicer already, even if you do have to do a total restoration.
PS. Even though this one isn't restored yet, it proved itself and was whole at one time already. Therefore, I am adding it to the post for trailers with lifting roofs: viewtopic.php?f=5&t=50969
Postby mezmo » Sat May 02, 2015 1:39 am
Is the structural framing wood Oak? The grain looks more pronounced than the usual softwood framing. Just curious.
I don't know if it would be worth it to you, but you could do a very close documentation of it all, with the view of making plans of it that you could sell. You wouldn't get rich but it'd be some compensation for the time you need to do all that, especially if you do it on 'your time'.
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby GPW » Sat May 02, 2015 6:11 am
“ Boy do I have some work to do. “ ... Yep !!! And a chance to do it right (leakproof) this time :roll: ... That really is a NICE camper design 8) ...
Postby capnTelescope » Sun May 03, 2015 12:19 am
The Wee-Zim reminds me very much of the Super Tear Drop (S.T.D. for short) built by our very own Vairman. It's got a drop floor, too.
This pic is from Vairman's gallery.
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby bohemian » Thu May 14, 2015 10:05 pm
Here's a few more pics. I know I missed a few shots, (rear nailer and the wheel well side support). :thinking: I'll have to remember to get those shots when I do the other wall.
Wayne
bohemian
Images: 233
Postby GPW » Sun May 17, 2015 8:03 am
Wayne , so you’re replacing one piece at a time , working your way around ??? And saving what you can ...? Which seems like a really Great idea for restoration as the trailer is never wholly disassembled ... :thumbsup:
Postby bohemian » Sun May 17, 2015 12:45 pm
I found that the only way I could keep the shape of the sides is to replace all the rotted wood while the sides were on, then I would put the outside sheathing on so I could remove the walls.
After the walls are removed I can start on the birch ply interior wall panels, then it's on to the frame and the floor.
It's a tad bit overwhelming when you think about all that needs to be done, basically all thats left to be reused, is the frame, axle?, and the aluminum side panels, and lets not forget the lifting system, all the rest will be trashed (water damage and squirrel stuff) :(
bohemian
Images: 233
Postby bohemian » Wed May 27, 2015 10:40 pm
Im finally getting around to building the new cabinets, I'll need them to hold the new walls up.
bohemian
Images: 233
Postby aggie79 » Thu May 28, 2015 7:53 am
Beautiful work Wayne. :thumbsup: :applause: :thumbsup:
bohemian wrote:It's a tad bit overwhelming when you think about all that needs to be done, basically all thats left to be reused, is the frame, axle?, and the aluminum side panels, and lets not forget the lifting system, all the rest will be trashed (water damage and squirrel stuff)
I hadn't notice the lifting system until you mentioned it so I went back and looked at your pictures again. I see how the "push rods" lifted the roof but there seems to be extra cables and pulleys for that operation alone. Does one system both lift the roof and lower the floor too?
Postby bohemian » Thu May 28, 2015 10:40 pm
The weight of the drop down floor lifts the back lid up, and pulling the lid down lifts the floor. The weight of the roof and the floor need to be very close in weight.
Very cool setup.
Wayne
bohemian
Images: 233
Postby bohemian » Fri May 29, 2015 9:31 pm
I have the left and right side cabinets done, now I'll start working on the finish.
Wayne
bohemian
Images: 233
Postby Recon26 » Fri May 29, 2015 9:33 pm
Fancy!
Recon26
Postby rebapuck » Sat May 30, 2015 9:37 am
Love the little closet cut out. You think it was for ventilation?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby bohemian » Sun May 31, 2015 10:10 pm
This would be my guess.
Wayne
bohemian
Images: 233
