My build has circular/radial curves, elliptical curves and compound curves. Following are my thoughts on your questions.
troubleScottie wrote:Sill in the design/thinking stage. Trying to work out a design. I am looking at peoples' various designs and design discussions and noticed that many of the designs are using circular rather than elliptical curves. The classic Grumman has elliptical lines. Is there some technical reason to use circular curves other than easier to cut ie a single pivot. I have found in the wood working sites an elliptical cutting jig which appears to make the task fairly straight forward.
My guess is that circular/radial curves are used because they are easier to layout than elliptical or compound curves. My teardrop has all three types of curves. (The upper front quarter of my teardrop profile is the "Trailer For Two". The lower front quarter is flat/vertical with a lower 6" radius". The rear of my teardrop profile is a blend of the "Grumman" and "Cub" profiles.)
I used a template to cut my sidewalls. To layout the profile, I drew a three inch grid and plotted the approximate x-y coordinates. I then placed angled wood stops using double-sided tape at the "hard points" and stretched a wood batten around the hard points. This technique helps blend/transition the curves and lines so that profile was smooth and there were no breaks. (I believe the term is that the curves and lines are tangent.) It did take a few tries with the batten and rearranging some of the hard points to get everything as I wanted.
On a few of my circular/radial curves I used a router with a home-made trammel (compass) to cut arcs. However, the majority of curves were rough cut free-hand and then I used a belt sander to final cut to the layout line.
troubleScottie wrote:Is it harder to bend plywood along an elliptical edge? It looks like it would be easier except as you approach the crossing of the major axis.
I don't think this is an issue in most cases. It is easier to bend the plywood on elliptical curve as the radius decreases than it is to bend plywood from a flat to a "tight" (12" or less radius). Going from the flat to a larger radius is not an issue. (This is predicated on using high-quality 1/8"/3mm plywood and not a thicker and/or lesser quality plywood.)
troubleScottie wrote:Is it harder to build a hatch that is elliptical ? Or if the hatch spans steepest part of the curve ( where the major axis joins the curve )
My hatch is a compound elliptical and radial curve. It is also longer (as are Grumman and Cub hatches) than most hatches. The lower rear radius of my hatch is 10". That was the most difficult part to "skin" with plywood.
As many others have said, it is best to frame your hatch in place. It will help greatly with maintaining the shape of the hatch and skinning it. If you do this method be sure you leave out part for the galley bulkhead so that you can remove the temporary fasteners to release the hatch.
troubleScottie wrote:Is it harder to get the two roof curves ie the inner roof line and outer roof line assuming you have a template with each curves (two templates).
I'm not sure what you mean by this. I don't have a picture of this but I made a jig to hold a pencil 1-1/2" inside of the profile line. I used this to layout the inner profile for the ceiling. (My spar depth is 1-1/2".)
troubleScottie wrote:On a related topic, what thickness of plywood can be easily bent without any cutting. It appears 1/8" works well. Can the same be said for 1/4" ply?
1/8" high quality plywood will bend easily to 18" radius. Less than that is more difficult but not impossible. I bent plywood around the lower 6" radius at the front of my teardrop. I would not try to bend 1/4" plywood, especially big box plywood, at any radii tighter than 18".
troubleScottie wrote:Are there curves that are too small? Obviously very small (3" radius) would be extremely difficult/impossible. But where is the break even point ie 10", 15", 20" ? I suppose one could try them out, but that could be pretty extensive/expensive building so many tests.
When you get below 12" radius with 1/8" plywood, things start getting difficult.
