KCStudly wrote:Not sure about that but it handled my little trim router just fine, and Karl was using it with a DA sander, too.
OP827 wrote:KCStudly wrote:Not sure about that but it handled my little trim router just fine, and Karl was using it with a DA sander, too.
All hand tools and small shop tools will be fine with this setup as they require much smaller current than table saws or planers. If you try this with a 110V 1.5HP+ table saw you'll know what I mean.
Will that not overload the curcuit with 12A of Vacuum and then 1.5HP table saw?
OP827 wrote:KC, Are you using two linear actuators for the hatch lift? Did you think of (synchronizing) them?
- to make sure you could do a check, by a very simple method, that there are no little sparks after you disconnect and connect the battery again after it stopped, but without changing the polarity. That is a "sparky" method while a tester is not around. BTW I would be surprised if not all 12V linear actuators have built-in end switches, simply from the vendor's warranty protection perspective.KCStudly wrote:Mine do seem to stop driving at the limits, so I assume built in limit stop switches.
- Looks like you have more than enough brain capacity at hand, I will be eagerly waiting for more informationKCStudly wrote:My chunker buddies include a math software expert who has been fiddling with Arduino as a hobby for a couple of years now, and at least one master of EE (Hi Dave!). I suppose there is an outside chance that I could get one or both of them interested in helping move us toward a home brewed solution. Not sure if that is an effective use of anybodies time, but it would certainly exercise my gray cells to dig into this.
