Pace America 7x12 Build in Seattle
Re: Pace America 7x12 Build in Seattle
Postby RetchedOne » Mon Mar 30, 2015 3:03 pm
One more
ceiling insullation2.jpg (52.48 KiB) Viewed 2641 times
And dinner that night
A reverse seared rib eye
RetchedOne
Images: 9
Postby RetchedOne » Mon Mar 30, 2015 3:16 pm
I am in the process of running wiring for the trailer wiring (stop lights etc), and will move onto teh runnign of 12v acessories and 120v wiring.
Trying to make a list of things to run that I may forget
- Thermostat
- black/grey/potable wiring for meters
One question on my insulation if anyone knows...
Currently the foam board reaches all the way down to the frame at the bottom of the exterior wall which is open the the elements under the trailer... I was going to just use spray foam (gaps and cracks) to seal between it and the sides of the trailer floor... But I may cut the board up a few inches (closer to level with the interior flooring) as to keep water from the road from pooling where the metal and foam board will meet.
Is spray foam OK to use to seal the floor/foam insulation/aluminum siding/Z strip studs???
After reading Pem's horror stories on mold, i'm wishing i didn't do foam boards and just spray insulated everything...
RetchedOne
Images: 9
Postby RetchedOne » Mon Apr 13, 2015 12:41 am
Finished the exterior lighting, switched over to LED lights.
Need to use the trailer for moving next weekend, so it's road ready now.
I will be adding another 1/2 inch to the sides before the 5/16ths skins go on.
Roof and front still need to have the insulation finished as well.
Once moved, the fun will begin.
Picked up a 41 gallon grey water tank 54" x 22" x 8" - fits between the rails. ( 109 shipped )
Have the furnace, AC water heater and rest of the tanks picked out. Just have to wait about 30 days to order.
2015-04-11 14.58.10 (Mobile).jpg (62.93 KiB) Viewed 2530 times
RetchedOne
Images: 9
Postby RetchedOne » Tue May 12, 2015 2:04 pm
Bought a bunch of goodies...
PD4045, another grey/black tank, water tank, NT-16seq, Atwood 6 gallon DSI water heater, toilet, water pump, etc... LED lights...
Just need to pick a A/C unit now...
RetchedOne
Images: 9
Postby Gonefishin » Tue May 12, 2015 3:04 pm
:thumbsup: Will be nice to see this one come together. Lots of "stuff" in a 7X12.
Gonefishin
Images: 119
Postby RetchedOne » Tue May 26, 2015 11:16 am
Got some more insulation in, wiring and two windows!
Did some more planning as well so I know where most stuff will go.
Good little guide on window installation -
http://www.rvwindow.com/RV_Products_Lis ... goryID=248
Window 2 inside
2015-05-25 14.41.27.jpg (50.08 KiB) Viewed 2335 times
Adding more insulation
2015-05-25 11.40.54.jpg (48.5 KiB) Viewed 2335 times
Smurf Tube run
2015-05-24 14.25.17.jpg (67.44 KiB) Viewed 2335 times
RetchedOne
Images: 9
Postby RetchedOne » Tue May 26, 2015 1:23 pm
One more pic -
Outside rear
2015-05-25 18.30.49.jpg (42.41 KiB) Viewed 2323 times
RetchedOne
Images: 9
Postby RetchedOne » Thu May 28, 2015 2:19 pm
Water heater is cut in -
Atwood 6 gallon DSI
Inside before
2015-05-27 17.54.17.jpg (56.21 KiB) Viewed 2253 times
Cut out
2015-05-27 18.25.06.jpg (58.99 KiB) Viewed 2253 times
Before
2015-05-27 17.54.05.jpg (40.62 KiB) Viewed 2253 times
RetchedOne
Images: 9
Postby RetchedOne » Thu May 28, 2015 2:21 pm
A few more -
Just need to add a few screws, a dab more sealant and the door.
Will brace it up as well.
2015-05-27 20.07.52.jpg (54.45 KiB) Viewed 2253 times
Installed
2015-05-27 20.01.57.jpg (47.66 KiB) Viewed 2253 times
Installed
2015-05-27 20.01.45.jpg (38.77 KiB) Viewed 2253 times
RetchedOne
Images: 9
Postby RetchedOne » Thu May 28, 2015 11:47 pm
Picker up a Coleman 13,500 ac upper for 200 tonight.
Need to support the roof a bit more I think....
Looks like I can order a support here -
http://www.tjtrailers.com/cgi-tjtrailer ... c1a68b7d42
RetchedOne
Images: 9
Postby RetchedOne » Wed Jun 03, 2015 12:20 pm
Bought my Awning -
Shademaker XL Supreme bag awning 11 footer in Blue
http://www.rvawningsrus.com/XL-Supreme- ... _p_25.html
Super nice guy at RV Awnings r'us
Highly recommend them!
RetchedOne
Images: 9
Postby RetchedOne » Thu Jun 04, 2015 2:50 pm
Welded in the roof bows / supports
The A/C should not fall through the roof now.
Added two roof bows to the support in front of the 14x14 hole and behind the 14x14 hole.
AC Roof Support
AC Support
RetchedOne
Images: 9
Postby RetchedOne » Thu Jun 04, 2015 2:52 pm
Picked up a small DC fridge
Draws 2.8 amps when running. I plan to make the fridge hole with enough future space to hold a 2/3 way 5 cuf fridge in the future.
RetchedOne
Images: 9
Postby hankaye » Fri Jun 05, 2015 9:02 am
RetchedOne, Howdy;
Nice find with the DC 'fridge got a link
or some kind of contact info. ???
hank
hankaye
Postby RetchedOne » Fri Jun 05, 2015 11:45 pm
Picked up a trailer hitch cargo thingy at harbor freight for 44 bucks today.
http://www.harborfreight.com/500-lb-cap ... 66983.html
I want to use the whole thing, but turning radius may be an issue... still need to measure, but so far half is all I needed.
Looks like "half" of it will fit nicely for my tongue setup with 2 GC2 6V batteries and a propane tank!
I will change teh A-Frame crank out to a side crank.
Haven't decided how to hold it down yet. need to leave room for the Weight Distribution stuff too...
Wiring is nearly done, starting cabinets tomorrow!
2015-06-05 17.49.26 (Mobile).jpg (84.47 KiB) Viewed 2034 times
two Norco GC2 battery boxes
2015-06-05 17.50.25 (Mobile).jpg (89.18 KiB) Viewed 2034 times
2015-06-05 17.50.32 (Mobile).jpg (93.25 KiB) Viewed 2034 times
RetchedOne
Images: 9
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
