Our latestest build - Temple, TX
Postby TxDave » Sun May 17, 2015 12:04 am
We're almost finished with our newest trailer. We went for a sort of modern retro look. This is the first time we have made our own doors, having previously used prefabbed ones. I welded the frame from 2x2" square tubing and added a storage area over the A-frame. The spare is stored under the front of the camper shell. This one has an air conditioner mounted in a vented aluminum lined box in the galley area. Using two different colors of aluminum to skin the walls was a little challenging, but it turned out pretty nice, I think.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Re: Our latestest build - Temple, TX
Postby rmclarke » Sun May 17, 2015 12:33 am
Sweet looking rig Dave!
(c'mon you gotta give us more pictures than that....... :thumbsup: :thumbsup: :applause: )
rmclarke
Images: 231
Postby Racquetman » Sun May 17, 2015 1:37 am
Looks real nice, I would love to see some more pics.
Racquetman
Postby TxDave » Sun May 17, 2015 4:32 am
Thanks folks. I'll put together a build journal soon. Just been too busy to post any pics. The frame features a fold-down cradle for the spare tire, and a storage shelf on the front A frame. All of the bulkheads and cabinets were installed using dado joints. My "temporary spars" keep everything aligned during assembly. Close-up shot shows the T molding around the door and the door handle.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby Vedette » Tue May 19, 2015 12:43 am
Another "Great Job" Dave! :thumbsup: :thumbsup:
You are an amazing builder. :applause:
Hope you are taking some time for camping, as it is the reward for all of the hard work.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Java Jack » Tue May 19, 2015 10:54 am
Nice. When you post your build journal it would be great to understand your design choices. For example, you chose leaf spring axles as opposed to torsion axle, why? How did you choose where to put the spare tire and how does it impact your weight distribution? How did you determine axle placement?
Thanks for the pics, it is a nice looking trailer.
There are 10 types of people in this world, those that understand binary and those that don't.
Regards,
Java
Proud Owner of a CampInn 560 Ultra
Blog: http://cre8tiveapps.blogspot.com/
Video: https://youtu.be/TLLFt3vzFoA
Sill Images: http://imgur.com/a/EE0zC#0
Java Jack
Postby robfisher » Wed May 20, 2015 9:13 am
Very pretty! Love the color scheme.
robfisher
Postby TxDave » Fri May 29, 2015 12:18 am
Thanks for the kind words, folks. Just about got this one finished. Managed to get a nice snug fit on the galley hatch. The hatch frame is welded 1/2" square steel tubing. If it will ever stop raining here in Central Texas we'll take it out for a trial campout.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby 2bits » Fri May 29, 2015 12:40 am
I did my second teardrop frame in 1/2 square tubing. When people think of metal and welding they tend to go over the top and forget the strength that is gained once it is welded together! I like how you did the two sheet of aluminum and overlapped and covered with trim, this is a neat way to do it!
Thomas
2bits
2bit Member
Postby TxDave » Thu Jun 04, 2015 9:41 pm
Got the gas struts for the galley hatch installed. Not as difficult as I had anticipated.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby 2bits » Thu Jun 04, 2015 10:11 pm
I assume the only hard part about it was locating the mounting positions, right? What method did you use?
Thomas
2bits
2bit Member
Postby TxDave » Fri Jun 05, 2015 12:25 am
I used a very elaborate high-tech method to determine the proper mounting location. I propped the hatch open at the height I wanted with a 2x4. Then I attached the strut to the hatch frame and then to the galley wall. Ended up having to move the upper attachment point about 2" closer to the hinge which worked out perfect. So, basically, just pure dumb luck. Sometimes things just work out despite my ignorance.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby pchast » Fri Jun 05, 2015 9:48 pm
pchast
Images: 97
Postby jpicklesgirl » Thu Jun 11, 2015 1:00 am
Sweet!!!!
jpicklesgirl
