Gage wrote:Any RV parts store will have it. I don't know of anywhere you'll be able to get it for free.![]()
Your teardrop is over 6' tall?
millerworks wrote:Well you can use schedule 40 PVC and cut a 1/4 inch slot out of it
millerworks wrote:If you aren't against screws you can countersink them thru the slot cut in PVC. Using stainless of course you can use maybe 1/2 inc just use a small enough cord
KCStudly wrote:Be careful pushing that PVC thru the saw. If you push too fast it goes "ka-bomb" and shatters. Also, that same internal stress that pinches it closed will tend to clamp on the back side of the blade which can cause kick back.
