Roof A/C install
Roof A/C install
Postby gisclair615 » Wed May 06, 2015 6:27 am
How are you guys bracing your roof for A/C install? Would I be ok with just adding 1" X 1" square tubing to box in the roof vent area? My a/c is a Coleman Mach 8 low profile and weighs around 90 lbs. This is how my roof beams are now.
gisclair615
Re: Roof A/C install
Postby wtcreaux » Wed May 06, 2015 9:52 am
Ordered mine beefed up from the factory........they doubled the transverse supports at the location (parallel to the originals, touching, welded together) then place the 2 short pieces perpendicular to make the vent space.
wtcreaux
Images: 211
Postby nunrleft » Wed May 06, 2015 2:08 pm
wtcreaux wrote:Ordered mine beefed up from the factory........they doubled the transverse supports at the location (parallel to the originals, touching, welded together) then place the 2 short pieces perpendicular to make the vent space.
Ordered mine from the factory with the a/c support. It was done this same way.
nunrleft
Postby gisclair615 » Wed May 06, 2015 2:43 pm
Do you have any pics of the way it's done? I think I'm understanding how it's set up.
gisclair615
Postby nunrleft » Wed May 06, 2015 10:35 pm
nunrleft
Postby gisclair615 » Thu May 07, 2015 1:16 am
Thanks for the photo. I'll just copy this with 1" x 1" square tubing. Thanks!
gisclair615
Postby gisclair615 » Wed May 20, 2015 8:03 pm
Got it braced and installed. Welded some 1" x 1" square tubing. It's very sturdy and strong
gisclair615
Postby gisclair615 » Wed May 20, 2015 8:04 pm
Trailer is due for a wash. It been sitting for a while.
gisclair615
Postby wanabxtrm » Fri May 29, 2015 8:36 pm
How do you like the mach 8? its on my short list for A/c's at this point. Have/can you measure the amp draw for me by chance? I'm curious if it aligns with the published specs or is lower (as I've read elsewhere).
Any other issues or complaints with the install?
wanabxtrm
Postby RetchedOne » Sat May 30, 2015 12:26 am
I'm adding a few Roof Bows to my pace trailer
http://www.hannarv.com/P/RoofBowTTBTopR ... ex7I/26314
RetchedOne
Images: 9
Postby gisclair615 » Sun May 31, 2015 7:03 pm
RetchedOne wrote:I'm adding a few Roof Bows to my pace trailer
Nice find. I was looking for those but couldn't find them.
gisclair615
Roof A/C install
Postby gisclair615 » Sun May 31, 2015 7:07 pm
wanabxtrm wrote:How do you like the mach 8? its on my short list for A/c's at this point. Have/can you measure the amp draw for me by chance? I'm curious if it aligns with the published specs or is lower (as I've read elsewhere).
I'm really pleased with it. I didn't think it would cool as good as it does being mine is only. 9200BTU. I only insulated with 3/4 foam board and it's been high 80's and upper 90's with high humidity and it freezes my trailer out during the day. At night it's on low with thermostat halfway. I don't have an amp meter to measure amp draw but I have a off brand 3k generator inverter and it doesn't struggle at all to run the a/c and fridge. Install was very easy and straight forward.
gisclair615
Postby RetchedOne » Wed Jun 03, 2015 12:19 pm
Bought 4
Should be here today and welded in tonight!
A/C by the weekend!!!
RetchedOne
Images: 9
Postby RetchedOne » Fri Jun 05, 2015 8:39 am
Welded in the 4 roof bows i bought online.
Pictures are deceiving, but I added two roof bows front and two behind the AC hole.
Used 1/4 inch flat bar to tie them together.
I can now do pullups on the bars and the roof doesn't move.
By pull ups I mean hanging there flailing like a fish...
RetchedOne
Images: 9
Postby RROADKILLL » Fri Jun 05, 2015 12:08 pm
RetchedOne wrote:I can now do pullups on the bars and the roof doesn't move.
Love it!!! Love it so much that it is now my singature!
-RetchedOne
RROADKILLL
