Robot wrote:KC, I like your attitude. If machining has taught me anything, it's that there are at least 5 different ways to do anything, and each will have its pros and cons.
My "good" corner plug and the second plug made from the "good" mold both flattened out after sitting out of the mold for a couple hours. I think there is just so much foam under tension that once it has nothing holding it back it "stress relieves". So much for the mold being the best method .
In a fit of frustration I installed the skeleton frame in the remaining 3 corners, duct taped the corner from the inside, and built up spray foam on the outside. I did not take pictures.
I was going to have to hand shape the corners regardless, and by spraying it directly on the trailer, it will encapsulate the corner skeleton, making a stronger unit.
Hopefully.
Robot wrote:Noseoil, ... that's what I think of every time I see your name.
KCStudly wrote:Robot, "Now you're cooking with gas!"Robot wrote:Noseoil, ... that's what I think of every time I see your name.
For me it is how my dad taught me to assemble a fly rod; roll the male ferrules in the corner of your nose before inserting them into the female ferrules. That way the rod comes apart easier when you go to take it apart. Just enough assembly lube to do the job.
I'm wondering if I can get the corners 90% smooth & round, then use some sort of body filler for the myriad of little cracks & holes.
