what do you think of this ac set up?
Postby martymcfly » Fri Jun 12, 2015 6:03 pm
http://boise.craigslist.org/rvs/5052261962.html Is is a window ac laying on its back? Did they just cut the bottom out of the cooler?
martymcfly
Re: what do you think of this ac set up?
Postby Midget » Fri Jun 12, 2015 6:08 pm
I'm not an A/C expert but it looks like it will take the outside air from the front grill and chill it before blowing it into the cabin. Would have been better to pull air out of the cabin, cool it and then blow it back in. This setup wouldn't be very efficient. Eat up a lot of electricity too.
Midget
Images: 91
Postby Shadow Catcher » Fri Jun 12, 2015 6:25 pm
It can not work for long if at all. The compressors have to be relatively level or it will starve for oil.
The complete enclosure of the coils mean no coolth. Having only the cooling duct means you have cold wet air assuming b y some miracle it might cool assuming you pull it out of the box and level it.
Postby ssutton » Sat Jun 13, 2015 4:21 am
The camper itself is very cool and looks like it may be worth the money. But I think that an AC system rework would be in order. Like others have shared, if it works at all it will not last long.
ssutton
Postby lrrowe » Sat Jun 13, 2015 7:50 am
Shadow Catcher wrote:It can not work for long if at all. The compressors have to be relatively level or it will starve for oil.
Is this why when I carry a refrigerator home in my truck and tip it on it's side, I am told to let it sit upright for 24 hours....for the oil to drain back?
Bob
lrrowe
Images: 439
Postby Shadow Catcher » Sat Jun 13, 2015 8:01 am
Bob, yes it.
That oil is very important. we had a freezer fail because it was on our unheated back porch and a cold winter caused the oil to congeal. They make heater coils to keep the oil free flowing in refrigeration compressors.
