Offroad Teardrop Plan/Build
Re: Offroad Teardrop Plan/Build
Postby capnTelescope » Sun Feb 16, 2014 3:02 am
Greg M wrote:Aren't they a bit pricy though?
Yeah, maybe so. OTOH, it sure simplified that part of the design a bit. Didn't have to stress over axle width, actual trailer width, spindle face-to-face, etc. And ground clearance. Don't forget ground clearance. For that, you have to compare to a torsion axle, and they're somewhat iffy.
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby wavebreaker » Sat Mar 01, 2014 11:32 am
Must be one of my worst habits not updating things :whistle:
The tear is coming along i am into doing final cabinetry and mechanical/plumbing and electrical hookups.
Alot of it takes time as i make jigs for everything to speed the process up next time.
UPDATE
As i used Iroko and cane for galley doors/drawers i thought to mix it up by changing style for inside cabin.
As i personally like the look of Louver doors i remade my jig and made some. Using Western yellow cedar old growth of course. Being a boat-builder by trade i have a good stock pile.
Jig
Door assembled
first coat varnish
Installed in cabin
Yhe structure of the Tear is done everything is built and sanded surfaced for final finish. couple of shots of outside with a door on passenger side.
Propane hot water mounted on passanger side. Still needs box over it after it is plumbed in .
Wiring and water system going into recess and cupboards in galley.
Assembled and mounted front deck for propane and battery's. Need it in place to run wires and propane lines.
Worked on installing the side boards in front and behind tires need to finish my fender mold so they need to be fixed in place.
Got hot water heater plumbed and box for it built. box not mounted just hanging there.
I finally got the last of my electrical bits so i dove into plumbing and wiring for a bit.
So most of the lower plumbing done i installed fridge and put galley lower doors on. Reinstalled drawers etc.
Finally got my main rear hatch attached ..
Cheers :beer:
wavebreaker
Postby pchast » Sat Mar 01, 2014 10:18 pm
pchast
Images: 97
Postby KCStudly » Sun Mar 02, 2014 6:03 pm
Looking great! :applause: :applause: :thumbsup: :thumbsup:
Postby glenpinpat » Wed Mar 26, 2014 3:44 pm
Great build! will hopefully start mine this spring/summer. Just curious on what size timbren axle did you use and if you have brakes with it?
glenpinpat
Postby wavebreaker » Sun Apr 06, 2014 10:58 am
glenpinpat wrote:Great build! will hopefully start mine this spring/summer. Just curious on what size timbren axle did you use and if you have brakes with it?
The one i have is actually the first of its kind.
Its the 2000/3500 lb so 2k suspension with 3500 lb spindles for electric brakes. when i first started dealing with timbren they did not make this combo after discussing it with their engineers its available as a stock item.
wavebreaker
Postby glenpinpat » Wed Apr 09, 2014 2:55 pm
Just called them all I need to decide is the tire size I will be using! Thanks
glenpinpat
Postby wavebreaker » Wed Apr 09, 2014 10:58 pm
your welcome ..
its a great suspension system i have been very happy with the ones i have used.
wavebreaker
Postby wavebreaker » Sat May 31, 2014 10:43 am
Been awhile since i added anything to this thread thought i should update it
Trailer as it sits right now is basically finished will try and catch this up to date over a few days.
One of the problems with offroad style trailers is finding fenders to cover larger tires so i made my own mold and cast some.
Other issue i had was for a sink. I really did not like any i could find on the net so again i made my own mold and cast 1
Installed my running boards
installed electrical panel and solar panels.
More later
cheers
wavebreaker
Postby Greg M » Sat May 31, 2014 11:48 am
All I can say is "Damn, that's nice!"
Greg M
*Geek Extraordinaire
Images: 85
Postby KCStudly » Sat May 31, 2014 7:23 pm
Nice!
Have it your way and the kitchen sink, too. :thumbsup:
Postby cantsitstill » Sun Jun 01, 2014 5:59 pm
Wow. Keep the pics coming
cantsitstill
Postby wavebreaker » Sat Jun 13, 2015 9:51 am
Wow been a year since I added anything to this. Trailer is finished and in use works well. Though I am going to change my suspension out this summer to independent air bag suspension. it will work better for areas I like to travel.
some completed shots of trailer.
Cheers.
wavebreaker
Postby lfhoward » Sat Jun 13, 2015 7:56 pm
Wow, that's an awesome build. Nice work! :thumbsup:
It looks like you've thought about everything, with gas, water, even a shower! Now that you've camped with it, what is your favorite thing about it, or what features you would recommend to someone else building an off-road trailer? (I love the solar-powered electrical system, by the way.)
Cheers,
Lauren
lfhoward
Postby noseoil » Sat Jun 13, 2015 8:50 pm
Beautiful job on design, fit & finish on your land yacht! Looks like it will tow well & take you where you want to go. Really nice job on the mill work, congrats.
137905
noseoil
Images: 670
