Pace America 7x12 Build in Seattle
Re: Pace America 7x12 Build in Seattle
Postby RetchedOne » Fri Jun 26, 2015 5:49 pm
Started installing the cabinets.
Also got the bag awning mounted... not sure I like it yet.. It's so high (to clear the door) that I'll need a ladder to put it away/roll it out.
2015-06-25 18.48.45 (Mobile).jpg (52.64 KiB) Viewed 2739 times
RetchedOne
Images: 9
Postby flboy » Fri Jun 26, 2015 5:53 pm
Nice work so far! Can't wait to see the finished product!.
BTW, what are you taking picture with? It is hard for me to get any perspective on my interior with a regular digital camera or cell phone. Do you have a special lens or something?
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby RetchedOne » Fri Jun 26, 2015 6:20 pm
Just a Samsung S5. I sometimes use the panoramic view mode.
RetchedOne
Images: 9
Postby McDave » Fri Jun 26, 2015 6:58 pm
Can you tell me your source for those black tanks?
McDave
Images: 412
Postby RetchedOne » Fri Jun 26, 2015 9:26 pm
McDave wrote:Can you tell me your source for those black tanks?
Best CHEAPEST place is Amazon with Prime.
They get them to you in two days, free with Prime, for under 130.00 each.
Best price outside of amazon was near 200 with shipping.
http://www.amazon.com/gp/product/B00J9C ... ge_o08_s00
Link to manufacturer
http://www.alphasystemsinc.com/files/ca ... 5-2012.pdf
The tanks on amazon go in and out of stock, just be patient. check every few days.
RetchedOne
Images: 9
Postby McDave » Sat Jun 27, 2015 1:29 pm
Thank you RetchedOne,
I'm getting closer to starting my build, just trying to get things together. Hopefully I can start in Fall after the heat and get mostly done before the snow. That leaves me about 2 weeks here in Montana. :lol:
McDave
Images: 412
Postby RetchedOne » Mon Jun 29, 2015 10:28 am
Got the PD4045 mounted in and wired up.
Need to connect in the 12v Feed, cut off switch and circuit breaker.
Should be mounting the batteries ( 2 6v costco batteries) this week. Need to finish some brackets for them
Ordered teh rest of my propane parts as well.
RetchedOne
Images: 9
Postby RetchedOne » Tue Jul 07, 2015 8:42 am
Making good progress...
The bed/storage/rear wall are shaping up.
Electrical is in and working. Just need to trim out the lights after the ceiling panels are finished.
A/C is in and working!!!
Poop tank is permanently mounted and the "load" sensors installed.
Hoping to be done in 10 days for camping in 12 :)
RetchedOne
Images: 9
Postby RetchedOne » Tue Jul 07, 2015 8:45 am
AC is IN and cools down the trailer nicely, even without the ceiling/rear wall finished yet.
AC is a used Coleman Mach 3 13,500 BTU.
Runs on my Champion 3100 Inverter generator just fine, still quiet too, honda.. pft...
http://www.amazon.com/Champion-Power-Eq ... B00BBDCE1S
RetchedOne
Images: 9
Postby RetchedOne » Tue Jul 07, 2015 8:58 am
Found a sweet way to make a sewer hose holder...
http://hulahutrvmods.blogspot.com/
RetchedOne
Images: 9
Postby RetchedOne » Mon Jul 13, 2015 8:53 am
Getting close...
Plumbing tests good with one small drip... course I hooked the pump up backwards.... :?
Water tank checks OK
Propane works, no leaks.
Water heater heats water.
Still hoping to be done Wednesday...
Need to finish the cabinet drawers and doors.
Fix a small water drip (Like 1 drip every 15 minutes)
Flip the stupid water pump...
Oh and revers the hot/cold on the faucet.. hooked that backwards up too...
Finish the ceiling insulation and panels, hook back up the AC.
Wont have everything 100% done...
RetchedOne
Images: 9
Postby RetchedOne » Wed Apr 06, 2016 7:36 pm
RetchedOne
Images: 9
Postby flboy » Wed Apr 06, 2016 9:14 pm
Very nice work! Well done. I am in process as well with my CTC Toy hauler, not quite as far along.
Don (Flboy)
flboy
Images: 378
Postby aggie79 » Thu Apr 07, 2016 8:31 am
I agree! Very well done. I like your layout and the use of the pre-finished plywood. (I love woodworking but absolutely hate finishing wood.)
In reading other posts - so hopefully I be knowledgeable if I someday am able to do a cargo trailer conversion - there have been comments about clearance for tanks and valves. You seem to have plenty of clearance. I know you mentioned the stringer depth helped, but did you "lift" your trailer ("flip" the axles) or is it the way it came from the factory?
Thank you for posting your pictures.
Postby RetchedOne » Thu Apr 07, 2016 8:32 am
I did flip the axle, so I got an extra 4 inches. This helped tank clearance and trailer ball height.
RetchedOne
Images: 9
