How many clamps did you need to build your trailer?
Postby UK-Corlett » Mon Jun 29, 2015 5:07 am
I have pulled in a few favors to amass 46 clamps.
133560
How many did you need? :lol:
UK-Corlett
Images: 220
Re: How many clamps did you need to build your trailer?
Postby capnTelescope » Mon Jun 29, 2015 10:01 am
I can't beat that, but about this many:
Not nearly as many as the beers I needed. :beer:
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby dogscats » Mon Jun 29, 2015 12:47 pm
The two of you have great set . The one's I get just disperse when I leave for the week. 4 Kids there and no one knows where they go.
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby jss06 » Mon Jun 29, 2015 12:48 pm
N+1
Where N is the number you have on hand and you still need 1 more that you have to improvise.
jss06
Palladium Donating Member
Postby Sparksalot » Mon Jun 29, 2015 1:20 pm
I used about 6 clamps. I also used a "whole bunch" of gravity clamps. Having a solid surface made use of gallon jugs of water practical to use weights when just holding a piece until the glue set was needed.
Sparksalot
Images: 687
Postby Mary C » Mon Jun 29, 2015 8:21 pm
I did not have enough but after cutting a 3 inch pvc pipe into 20 one inch slices along with the 10 clamps I had I still had to use bricks, water jugs, paint gallon cans and even flower pots.
Mary C.
Mary C
Images: 473
Postby dguff » Mon Jun 29, 2015 8:28 pm
I have about 20, a variety of spring clamps, screw clamps, c clamps and bar clamps.
Jerome
Jerome
2008 Guffman
dguff
Images: 69
Postby Breytie » Tue Jun 30, 2015 12:54 am
I need at least twice as many as I do have
I do have
10 x Nylon 9" spring clamps
6 x cast 6" C/G clamp
6 x cast 4"C/G clamp
10 x pressed 2" C/G clamp
4 x 36" ratchet clamps
2 x 4' sash clamps
numerous purpose made wooden beam+blocks+wedge clamps
Threaded rods with all kind of accessories.
Ratchet straps
Many gravity clamps
Experience is learning from your own mistakes
Here I make mine in public: My build
Breytie
Images: 36
Postby S. Heisley » Tue Jun 30, 2015 5:46 pm
Mary C wrote:I did not have enough but after cutting a 3 inch pvc pipe into 20 one inch slices along with the 10 clamps I had I still had to use bricks, water jugs, paint gallon cans and even flower pots.
Mary C.
I'm with you, Mary! A half empty paint can with a stone on top of it becomes more than half full! This was when I was laminating the deck plywood together:
But, I do have about 25 clamps, many of them in use with wood assists, in this picture:
In the end, home trailer builders being people with ingenuity, we find a way to get the job done.
Postby azgreg » Tue Jun 30, 2015 6:20 pm
jss06 wrote:N+1
Wouldn't that be N-1?
azgreg
