The Mad Dash begins...
Re: The Mad Dash begins...
Postby GPW » Sun Jul 19, 2015 8:58 am
It’s been HOT here for months ... :roll:
looking really Good Mike !!! :thumbsup: 8) :applause: :beer:
Postby KCStudly » Sun Jul 19, 2015 9:37 am
mikeschn wrote:The upper piece is made by laminating 4 pieces of .1875" thick pine strips together.
Nice. I must have missed that. :thumbsup:
Did you laminate them over a form and then glue them in, or were you able to glue them in place?
Postby mikeschn » Sun Jul 19, 2015 11:56 am
KC,
I glue all 4 pieces in at the same time and clamp them up until they are dry.
@Glenn,
I am not used to this heat. I walk outside, and within about 30 seconds I am sweating. Within minutes I need a towel, and within a few minutes more I have to jump into the pool. I seem to pick the worst weather for building!!!
Postby mikeschn » Sun Jul 19, 2015 2:23 pm
JonW came over and we decided to POR15 the trailer...
http://www.por15.com/POR-15-Rust-Preven ... g_p_8.html
Here's the before:
Here's the after the first coat; next coat in a few hours... :
Postby mikeschn » Mon Jul 20, 2015 3:47 pm
Okay that's the 2nd coat. All done! Lets start building!
Postby capnTelescope » Mon Jul 20, 2015 10:14 pm
I assume the POR15 product you used was the rust preventive paint and not the bed liner?
Also, your link to por15.com (two posts back) has a semicolon at the end that causes the link to fail. Could you edit that for us, please?
On to the exciting part! :beer:
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby mikeschn » Tue Jul 21, 2015 2:38 am
Capn,
I fixed the link.
Yes, it's the rust paint, not the bedliner. Thats the nicest paint I've ever used on a trailer!!!
Postby GPW » Tue Jul 21, 2015 7:24 am
Trailer lookin’ Good !!! 8) Hope that paint holds up like they say it does .... I’d like to try it on an old rusted trailer .... :thinking:
Postby mikeschn » Tue Jul 21, 2015 3:30 pm
Canvas just arrived. Gotta pick up the pace. :sweaty:
Postby Fred Trout » Tue Jul 21, 2015 4:15 pm
mikeschn wrote:Canvas just arrived. Gotta pick up the pace. :sweaty:
No matter how fast you go,
murphy will make you slow,
so try your best and go out west,
in time for the powder snow !!
8) :x :oops: :cry: :R :twisted:
Fred Trout
Postby GPW » Wed Jul 22, 2015 7:38 am
Old saying .... “ Covering should be an unhurried job !!! “ ;)
Postby mikeschn » Wed Jul 22, 2015 7:29 pm
Came home from work today determined to do some work.
So I cut the floor to length... 15° on the back 18° on the front
Then I figured I'd try the gripper on a large surface, i.e. the inside of the wall.
I think it turned out pretty good. In the past I've used 7 oz canvas, and it shows all the imperfections. The 10oz canvas I got this time does a much better job at hiding the imperfections.
I didn't size it, so it's stretching itself taught. Also, I did not put gripper on the top yet. I didn't want to pull the canvas away from the foam and cause bubbles. Once the gripper has dried I'll do all the waterproofing stuff.
Postby Fred Trout » Wed Jul 22, 2015 8:29 pm
Gripper is nice stuff isn't it ? You might consider putting a coat of slightly thinned TB II on top for the bump resistance it confers. TB II dries much stiffer than Gripper or any paint I have used. The more you thin the TB II, the longer the cure time; about 5-10% is all that's needed to make it flow better than out of the bottle.
Fred Trout
What's Gripper?
Postby capnTelescope » Thu Jul 23, 2015 12:03 am
:question: For we, the uninitiated, What's Gripper? TIA.
Brad
capnTelescope
Images: 368
Postby Fred Trout » Thu Jul 23, 2015 12:16 am
capnTelescope wrote::question: For we, the uninitiated, What's Gripper? TIA.
Glidden Gripper primer - a very thick PVA latex primer that has excellent glue-like properties & dries more readily than other product when used to glue large styrofoam panels to each other, or foam to metal, etc.
http://www.homedepot.com/p/Glidden-Prof ... /100166028
Fred Trout
