JmsCaverly wrote:I like the idea of having everything on their independent grounds but also looped together will make for good trouble shooting of nesseccary but I'm not sure I can use self taping screw in 1/8 steel??? Or is that possible I plan to have all the grounds figured out before painting the frame so I don't have any issues with bad grounds
JmsCaverly wrote:First off thanks for all the help guys in taking the time to explain the different ways of getting a good ground. What are your thoughts of welding small bolts near light positions to get direct grounds instead of taping screws in to help prevent from putting to many holes in the steel frame?
JmsCaverly wrote:What size gauge wire are you guys using for you charging systems. I planing on using a 10ga wire straight from the battery to the connector. Or is that too much?
H.A. wrote:Without a lesson in electricity basics...
10 awg would work. But...
Bigger is better when it comes to battery charging circuit.
When charging 12v batteries, every fraction of volt lost within resistance of the charging circuit will greatly affect time required of fully recharging.
Perhaps go as large as your connector plug will accept.
Dont forget your ground conductor,
At minimum same size as your battery charging wire, but bigger is better as ground carries also negative current of battery charging and lighting, brakes, etc.
Dale M. wrote:Wire size is important... But also consider what size fuse will be supplying your 12 volt going to rear of TV for trailer power (charging).. My Chevy PU came with 40 amp fuse.... So there is some sort of current limiter and sort of a hint what wire size may be ok....
Also you are dealing with current inrush... The first 10-15% (or there abouts) of charge time current load will be heavy but once battery in TD starts to equalize with battery in TV current load will diminish over time to a point where TD battery is equal to TV battery and current flow will be minimal.... Your 10 gauge wire probably will handle the "load" just fine
Adding second connector for charging lead is next level of complexity that you don't really need... And will become just another thing to deal with at hook up/un-hook time...
Dale
