'47 MobilGlide maiden voyage went great!
Re: '47 MobilGlide and so it goes........6/27
Postby doug hodder » Wed Jul 29, 2015 9:16 pm
I managed to get the Marmoleum flooring installed, and last night finished up the door side floor cabinet. The electrical panel and the alarm system will go in the bottom, upper 2 drawers are for clothes, it still needs a top for it. I also am using some highly figured birch for the face on the galley. I shot some finish on it tonight, but still needs a couple more coats. Also got the original ice box restored which will go into the large opening on the right hand side of the galley frame.
It's 7pm and still 95F in the shop. This won't go out this year, as the cabinetry and interior is killing me on time. That's OK...I still have 2 others to use in the meantime. Thanks for watching. Doug
Re: '47 MobilGlide and so it goes........7/29
Postby S. Heisley » Wed Jul 29, 2015 10:02 pm
It looks good, like I knew it would!
But I've got to ask....Alarm system? This is the first one that you've used that in, isn't it?
Postby halfdome, Danny » Wed Jul 29, 2015 11:04 pm
I like the figured birch you're using.
Everything looks great as usual.
Does the top drop down (notch?) where the top rail is lower on the right?
What goes in that spot?
I tried to PM you a few days ago and it wouldn't work.
Jane & I were concerned for your welfare when we saw a large fire in your area on the nightly news.
You must be okay, if you're posting this.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Ron Dickey » Wed Jul 29, 2015 11:48 pm
Doug,
Each time it gets better and better :thumbsup:
If you get it out of the garage should bring it down to the Pismo Vintage trailer show. May 2016 or 17
173882......173887
Ron Dickey
Images: 787
Postby doug hodder » Thu Jul 30, 2015 8:58 am
The 1950 Port O Stove goes in the notch on the galley Danny. There was a fire fairly close, but not like last years King fire. Doug
Postby Junkboy999 » Thu Jul 30, 2015 2:25 pm
Another great looking trailer and fine piece of art. :thumbsup:
Love to be able to see one of them one day, when I get back on the road camping.
Junkboy999
Images: 52
Postby Ron Dickey » Fri Jul 31, 2015 9:35 pm
hey doug,
I found the car to pull it with it is a 1948 Studebaker with 10,000 miles on it they want $11,000 for it.
http://www.yourimmotors.com/inventory/v ... SCADERO-CA
Ron
173882......173887
Ron Dickey
Images: 787
Postby doug hodder » Sun Aug 30, 2015 9:24 pm
This weekend I managed to get back on the MobilGlide. I took 1 weekend to get ready to go camping in the Voyager, cleaned it and loaded it up, then 7 nights up at Wolf Creek with a group and had to unload on last Sunday, work a week and this weekend got back to it. I managed to get the restored vintage ice box installed in the galley frame and insulated. I have 1.5" of insulation on an original Modernaire ice box and it's a lot better than the original that was wrapped with 3/4 inch of fiberglass. It did drop the temp really well and held over night with a medium block of ice in it. I also did the final install on the lower cabinet and the upper. The laminate on the top of the cabinet is a faux marble white and gray. I'm wanting to push and get the woodwork all done before the temps drop and I can't spray finish outdoors. Thanks for reading. Doug
Postby Vedette » Sun Aug 30, 2015 11:59 pm
Doug
You have amazing woodworking skills! :thumbsup:
Beautiful job! :applause: .........can't wait to see it in person.
Are you looking for a Vintage tow car?
The Studebaker was a little to spendy for a '48" and a 4Dr. to boot. :thinking: There are better deals out there!
See you in the spring!
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby doug hodder » Sat Sep 12, 2015 11:14 pm
I got the galley mostly done, restored a Modern ice box that I scrounged from a '57 Mercury trailer that I scrapped. It now has 2" of insulation around it, much better than the crappy glass insulation it originally had. Stove is a late 40's Port-O-Stove, propane that I restored. Galley rails are aluminum strap and some spacers, all-thread and acorn nuts. Both the sink and the stove areas will get a top for a flat galley area. Color difference in the panels will be OK as it will match the rest of the skin on the interior. Still needs the details on the doors. The panel under the sink has the classic 3 vents that were so typical on an under sink panel back in the 40's, doctored it up with a couple of mahogany plugs. While the doors may not appear to match, they will match the rest of the interior just fine. Doug
Re: '47 MobilGlide and so it goes........9/12
Postby halfdome, Danny » Sun Sep 13, 2015 8:53 pm
Looks great Doug :thumbsup: , especially with the figure in the wood showing up under your finish.
I like your design, it's very inviting to the onlooker.
I'm confident this trailer will look and function considerably more than the original manufactures concept and build.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby S. Heisley » Mon Sep 14, 2015 8:49 pm
Unique and more than beautiful! :thumbsup: :applause:
Postby smeerkees » Wed Sep 16, 2015 3:32 pm
Biggest compliments Doug.
I realy like this build.
Greets, Kees.
(From the Netherlands.)
smeerkees
Postby doug hodder » Fri Oct 16, 2015 9:19 pm
Last weekend I installed the galley, but not the final install, had to put it in to trial fit up some of the other items. Managed to get the back splash done. It's a random scuff on some .040 aluminum with 2 coats of auto clear on it. It will get cut down to fit, and won't be so overwhelming once it's all done up without a flash from a camera on it, trust me. I also managed today to get the front and rear upper cabinets installed. Doing a rail and stile type face frame on a curve mated to a bottom shelf with a similar curve turned out to be quite a challenge for this woodworker. What's not shown is the speaker grills that are going to be made out of mahogany for the 2 end panels in the front cabinet. It's nice to get a lot of the parts that have been building up in the living room finally installed. I've been working really hard on getting a lot of the wood work done so I can shoot finish on it while the weather holds. I don't have an "official" spray booth, right now, it's the EZ up in the driveway. This isn't a resto..MobilGlides were really "plain Jane". Thanks for reading. Doug
Re: '47 MobilGlide, now with galley and upper cabinets! 10/1
Postby halfdome, Danny » Fri Oct 16, 2015 10:15 pm
Doug, looks like you pulled off the radius stile/rail quite well as it looks 90 degrees to the other stile & rail. :thumbsup:
I'd imagine finding the correct radius was the biggest challenge, challenge is good for all of us.
I like the look your creating, thanks for sharing.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Users browsing this forum: Google [Bot] and 4 guests
